Windows 7: Troubleshooting Internet Explorer Issues
Published by Capt.Jack Sparrow
07 Jun 2010
Note   Note
You might have issues with Internet Explorer like not opening or crashing often not loading pages etc. Here are few troubleshooting steps that you can do to fix certain issue.
1. The first step which always you could try is to disable the add-ons and see if that works or fix the problem that you have with IE.
Start | Under search | Internet Explorer (No Add-ons)
It will open the Internet Explorer without any add-ons then see if you have the same problem. If that fixes it then next thing is to enable the add-ons one by one to find the culprit.
a. Click the Tools button, and then click Manage Add-ons.
b. Under Show, click All add-ons.
c. Click the add-on you want to disable, and then click Disable
2. To delete ActiveX controls
1.Open Internet Explorer by clicking the Start button , and then clicking Internet Explorer.
2.Click the Tools button, and then click Manage Add-ons.
3.Under Show, click Downloaded controls to display all ActiveX controls.
4.Click the ActiveX control you want to delete, and then click More information.
5.In the More Information dialog box, click Remove.
3. Next steps which used to fix almost all the issues with Internet Explorer is to reset the Intenet explorer to Default Settings
1. Close any Internet Explorer or Windows Explorer windows that are currently open.
2. Open Internet Explorer by clicking the Start button , and then clicking Internet Explorer.
3. Click the Tools button, and then click Internet Options.
4. Click the Advanced tab, and then click Reset.
5. Select the Delete personal settings check box if you would like to remove browsing history, search providers, Accelerators, home pages, and InPrivate Filtering data.
6. In the Reset Internet Explorer Settings dialog box, click Reset.
7. When Internet Explorer finishes applying default settings, click Close, and then click OK.
8. Close Internet Explorer.
Your changes will take effect the next time you open Internet Explorer.
OR
You could use Mircosoft Fixit Tool to do it for you.
Click this link to download it Reset Internet Explorer settings
Note: This will delete personal settings, some webpages that rely on previously stored cookies, form data, passwords, or previously installed browser add-ons might not work correctly. Resetting Internet Explorer's settings is not reversible.
4. IE is slow to start and/or open new tabs check this article this should help to fix most of the performace issues Unshackling IE8 Performance - EricLaw's IEInternals - Site Home - MSDN Blogs
5. Video freezes or crashes in Internet Explorer or Windows programs
6. Often connection problems are caused by malformed winsock entries and invalid LSPs (Layered Service Providers). LSP entries are responsible for managing your inbound and outbound internet traffic.
Start | CMD | Right Click and Run as Administrator
netsh winsock reset catalog (resets winsock entries)
netsh int ip reset reset.log (resets TCP/IP stack)
Reboot the System then Test it.
7. Quite frequently, internet connection problems can be traced to a corrupted DNS cache. Resetting or Flushing this cache is an easy fix to many of these problems
ipconfig /flushdns
ipconfig /release
ipconfig /renew
8. I found a Batch File created by an MVP Kai Schätzl Internet Explorer FAQ - Repair IE8 (IE7)
Then see if you can connect to any websites.
Captain
07 Jun 2010   #1
derekimo
Nice Work Capt., This will come in handy.
07 Jun 2010   #2
Capt.Jack Sparrow
Quote   Quote: Originally Posted by derekimo View Post
Thank You Derek !!
07 Jun 2010   #3
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Nice one Cap'n!
07 Jun 2010   #4
Capt.Jack Sparrow
Quote   Quote: Originally Posted by Bare Foot Kid View Post
Nice one Cap'n!
Thank You Ted !!
07 Jun 2010   #5
CarlTR6
Windows 7 Ultimate 32 bit
Another nice one, Captain. Good work.
07 Jun 2010   #6
Capt.Jack Sparrow
Quote   Quote: Originally Posted by CarlTR6 View Post
Thank You Carl !!
07 Jun 2010   #7
WindowsStar
Looks good Capt.
07 Jun 2010   #8
Capt.Jack Sparrow
Quote   Quote: Originally Posted by WindowsStar View Post
Looks good Capt.
Thank You !!
08 Jun 2010   #9
Joan Archer
Windows 7 Ultimate SP1 32 bit/Windows 10 64bit
A very useful and informative tutorial Capt. it could help a lot of people who may have problems with Internet Explorer, nice work.
Random Lag, possibly explorer.Troubleshooting issues.
I am currently having issues with random lag on explorer and programs. What it is exactly doing is giving unresponsive for about 30 seconds on programs such as firefox, thunderbird, explorer.exe. Thought it may be a resource issue but doesnt appear to be. Here is the full version: I...
Performance & Maintenance
Request: Good Debug/troubleshooting tool for Internet Explorer
Hi, I'm looking for good debugging/troubleshooting tools (prefer something with GUI) I can help my clients with. Specifically for Internet Explorer would be great. Any recommendation would be appreciated.
Browsers & Mail
Internet Explorer 9 Issues
Guys, I recently upgraded to IE 9 and I keep getting the "Internet Explorer has stopped working" message. On the most recent one here were the problem details: Problem signature: Problem Event Name: BEX Application Name: iexplore.exe Application Version: 9.0.8112.16421
Browsers & Mail
Troubleshooting Explorer.exe Crashing Issues
Troubleshooting Explorer.exe Crashing Issues I have seen lot of scenarios where users posting Explorer.exe crashing or stopped working issues. After troubleshooting lot of issues I'm posting here some common fixes that might help. 1. Most of the times the Explorer crashes due a bad...
Crash and lockup debug 'How To'
internet explorer issues
how can i use internet explorer 32bit on a 64 bit windows. i cant seem to get it to work. i cant use flash player stuff on windows and am having issues viewing things because it says it cant run on a 64bit browser.
Software
Internet Explorer 8 - Issues
Internet Explorer 8. This may be real simple for some. But I can't figure it out. I may be using incorrect terminology or words here but I hope someone can get the gist of what I am seeking. In Internet Explorer 8. I open. Go to any website. For simplicity sake I will make up names. ...
Browsers & Mail
