Windows 7: Multi Router Network - Configure
07 Dec 2012   #40
Morinmore
Nice write up and thank you for it.
Ok i just want to ask is this what i would do for my setup or some thing a bit different. Here is what i want, i have more then 10 items online and i want to have some on one network and the others on another one.
House setup is this, my wife and 2 kids live upstairs and mother/father and brother in-law down stairs and 1 internet connection, some hardware in the house is
4 HTPC's
3 XBOX's
2 PS3's
5 PC's
4 Laptops
1 Media Server
and phones and other items that use the internet
What i want is to have all the adults stuff on one router and have the kids on the other along with there friends when they come over so that if they don't do as there told, well you know what will happens with the internet lol.
So that means 4 HTPC's 2 XBOX's 2 PS3's 2 Laptops and the media server on one router and the rest and the visiting kids on the other router.
Routers in the house are Cisco DPL3825 (Given to us From ISP)
Linksys E3000 Kids router
Netgear WNDR3700v2 Adults router
Ohh and to make sure the kids router does not need to talk with the adults one at all
It this write up the same way i would set mine up or is there some thing different i need to do.
Thanks for the help
10 Dec 2012   #41
edwar
7 x64
I have to disagree with the DHCP Pool settings. If you only have 2 to 20 computer, or even more, you shouild not set the DHCP Pool from .2 to .252. This stops you from assigning Static IPs to things like Printers, which IMHO should always have a static IP. Yes some routers allow you to use the DHCP Pool for static IPs but most do not. Also some router have DHCP IP assignments by MAC address. That is fine if you use them for all or most of your Ethernet devices. Again some router do not have that feature. So if you use don't assign static IPs to things like printers at some point they will get a different IP from the pool and no one will be able to print.
10 Dec 2012   #42
wilnap69
windows 7 64 bit
one question! do i need two separate telephone line for two routers?
05 Jan 2013   #43
HerrKaLeun
W7 Pro 64
Good tutorial and I successfully set up the switch and can use that as a second wireless access.
I want to connect wired devices to the switch, is that possible at all? I have tried but it doesn't seem to work at all. Is there something I need to set if i want LAN in addition to Wifi from that switch? OR is this a function of the router and I need a new router? I use an old Netgear WPN824v2 as switch.
I noticed the routers have "RIP" settings. do they mean anything for this? (the router kind of explains what it is, but not sure what it means)
BTW, I learned the hard way that the switch LAN cable from the Gateway needs to be plugged into one of the 4 ports, and not in that single port normally coming from the Modem. The booby trap here is that it still shows a strong wireless signal, but doesn't actually work (I tried with my phone). I also decided to give switch a different SSID so I see what I'm currently connected to. My devices automatically connect to the stronger signal anyway.
14 Jan 2013   #44
cyclone3211
Microsoft Windows 7 Professional 64-bit Service Pack 1
Thank you for the tutorial, it made sense and I have a setup. I also bought an extender from Netgear to reach further with wireless. My thought was that this would extend the range of my current SSID. I was surprised that the SSID_Ext was provided which turns out to be a separate WiFi item.
My question is there a way to have that extender be on the same SSID as my original and not separate a different SSID requiring a different password?
15 Aug 2013   #45
caper26
windows 7
11) Connect the Gateway to the Switch via Ethernet.
Connect how? LAN of Gateway to LAN of switch? or to the WAN port of switch?
Switch = Router 2.
14 Dec 2016   #46
ellellell1
Windows 7 64-bit SP1 (VM)
Still refering to this tutorial for others who are interested. Easiest and clearest one I have seen so far!
Love the clear clafication for two different static IP ranges, most other tutorials always miss this one out...
How to configure wifi router 2L-WR307
I was searching for configuration help online but couldn't find it please help me Link to router specification: Wireless N Router 2LooK 2L-WR307 300Mb/s beži
Network & Sharing
Unable to configure network properties
as you can see the properties button does not lit up and remains grey out although i click on IPV4, why is this happening? i was open it a few years ago
Network & Sharing
How To CONFIGURE TP LINK ROUTER as ACCESS POINT in an existing network
Guys, I am having a hard time configuring my Access point. I have a DSL Router connected to our telephone line and it works fine wirelessly, Yesterday I purchased TP LINK Router to configure as Access Point to extend wireless signal up to the second floor. Now, I am wondering, should I do some...
Network & Sharing
How to configure tomato on linksys router?
i finally hae my comp back up and running.i need to know if there is a way to configure tomato on my router so it gets the best performance. is there a tut somewhere or a pdf? i hear it is really good but i hae no knowledge of using it, could someone p[oint me in the right direction please?
Network & Sharing
how do I configure this router for VPN
Hi, I am trying to setup remote access for our work pc's using VPN, for 4 different work pc's/users. I am getting close but can't quite get it to work. Attached is an image of my router's VPN configuration page. I know I need to use port 1723, but I can't seem to use the same port number for all of...
Network & Sharing
Cannot find configure router wizard anymore
Hi, today I got Internet and the technician plugged in a Motorola SURFboard cable modem (not a wireless router). After he left I could see the device - I don't rember where - in "Devices and Printers"?, in "Network and Sharing Center"? I clicked on the device icon and a wizard started which...
Network & Sharing
