Windows 7: SF Diagnostic Tool - Using for Troubleshooting
06 Jan 2013   #120
Northernsoul55
Windows 7 Professional 64bit
Pretty new to BSOD's and its certainly helped me.
Jack Sparrow: "I think we've all arrived at a very special place. Spiritually, ecumenically, grammatically."
Cheers
Dave
06 Jan 2013   #121
ICIT2LOL
HUm just wondering how long the features take to run as I sat for ahalf an hour waiting for a result from event viewer and I just got an exception etc etc message??
13 Jan 2013   #122
Haze
Win 7 64-bit Home Professional
I was able to run this tool yesterday with success. Today when I try to run it I am getting an exception error. Image attached. I am logged in as administrator and chose run as administrator.
15 Jan 2013   #123
darknightz0117
So..... I just used driver verifier via the Start menu and it crashed like a million times. I finally got it to stop and now I'm using this tool to collect everything and zip it up. I got the window where it said "Event logs Copied SUccessfully" and I clicked okay... but the window is still there, and nothing seems to be happening with the tool. WHen I try to go to the other window, it automatically puts the SF Diagnostic Tool window on top, so I can't click okay on that window anymore. Do I just let this sit?
15 Jan 2013   #124
ICIT2LOL
Quote   Quote: Originally Posted by darknightz0117 View Post
Yep which is basically what is happening in my app.
19 Jan 2013   #125
simonphinix
Windows
Hi everybody, I have a BSOD problem so I installed SF D.Tool. However it doesn't work when i open it. I ran it as administrator. A window says "SF Diagnostic Tool has stopped working". Here is the details:
Quote:
Description:
Stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: SF_Diagnostic_Tool.exe
Application Version: 5.0.0.6
Application Timestamp: 508b892b
Fault Module Name: mscorwks.dll
Fault Module Version: 2.0.50727.5420
Fault Module Timestamp: 4ca2b820
Exception Code: c0000005
Exception Offset: 000154c0
OS Version: 6.1.7601.2.1.0.768.2
Locale ID: 1055
20 Jan 2013   #126
simonphinix
Windows
I don't know what does it mean but i typed sfc/scannow in command prompt and restarted, appcrash problem is solved.
28 Jan 2013   #127
kr236rk
Re:SF Diagnostic Tool v5 For Troubleshooting: I'm afraid this just hangs at about 1/3 green line.
Please advise.
Thanks,
Ric
03 Feb 2013   #128
Arc
Captain, what should I say them to do in such a situation?
http://www.sevenforums.com/crashes-d...ml#post2279183
09 Feb 2013   #129
Capt.Jack Sparrow
Quote   Quote: Originally Posted by Arc View Post
That's weird ... The tool is not able to find the HOST file in that location.
SF Diagnostic Tool
Good Evening Folks: As per the instructions contained in the SF Diagnostic Tool, please find attached the results of the scan. Please note the Minidump scan reported that there was no file. Regards Powell Lucas
BSOD Help and Support
Is there a Mouse Diagnostic tool?
I have a Logitech MX300 with wireless 3 button mouse. The left, right and scroll wheel work fine, the center button doesn't seem to work at all. I have the latest version of SetPoint and tried setting it up with different key mappings but to no avail. I'm not even sure if it's working. Is...
Hardware & Devices
WMI Diagnostic Tool for 64-Bit
When I execute version 2.0 of the Microsoft's WMI Diagnostic Tool on my 64-bit Home Premium system, I get an 'Unsupported OS version or build #' error. Am I doing something wrong? If the tool doesn't work on 64-bit, is there a similar tool available which will? Thanks!
Software
memory diagnostic tool
does win 7's memory diagnostic tool always takes a long time from 21% to 22% on extended run? standard, short tests finish quickly i can run 2/3 tests in no time at all
Performance & Maintenance
SF Diagnostic Tool
SF Diagnostic Tool is to collect the information required to Analysis Blue Screen of Death and other troubleshooting purpose. Tool has been replaced with the GUI version http://www.sevenforums.com/tutorials/92394-using-sf-diagnostic-tool-troubleshooting.html Hope this helps, Captain
Crash and lockup debug 'How To'
