Windows 7: SF Diagnostic Tool - Using for Troubleshooting
Using SF Diagnostic Tool for Troubleshooting
Published by Capt.Jack Sparrow
19 Jun 2010
Using SF Diagnostic Tool v5 For Troubleshooting
information   Information
The SF Diagnostic Tool and SF Debug Tool is used to collect diagnostic information from your computer required to analysis Blue Screen of Death (BSOD) and other troubleshooting purposes for Vista, Windows 7, and Windows 8.
You must be logged in as an administrator to be able to use either tool.
Note   Note
SF Diagnostic Tool created by Shyam (Capt.Jack Sparrow).
Changelog for 5.0.0.6
  • Fixed typo in button
  • Added DXDIAG log
  • Added System Info Log - Log will also contain product ID, I was told with product ID we could find if Windows is genuine or not.
  • Minor bug fixes
warning   Warning
Some antivirus or firewall programs may detect SF Diagnostic Tool as a Trojan. It's just a False positive because the publisher is unknown.
There is nothing to worry about as the SF Diagnostic Tool is 100% safe and will not harm your computer.
Here's How:
1. Click/tap on the Download button below to download SF Diagnostic Tool.
download
2. Save the ZIP file to your desktop, open it, and extract (drag and drop) the SF_Diagnostic_Tool.exe file to your desktop.
3. Right click on or press and hold the extracted SF_Diagnostic_Tool.exe file, and click/tap on Run as administrator.
4. If prompted by UAC, then click/tap on Yes.
5. Click/tap on the Grab All button, and click/tap on OK for each notice dialog until it's finished.
6. You will now have a folder saved on your Desktop with the name of SF_DD_MM_YYYY (SF_day_month_year) that includes the information from each button in the tool.
7. ZIP the SF_DD_MM_YYYY folder, then rename the ZIP folder to your user name here at Vista Forums, Seven Forums, or Eight Forums.
8. When you are finished, you can close the SF Diagnostic Tool.
FAQ
1, If you're getting this error below, then instead of clicking on Grab All, click the buttons one by one in order to see which one is giving you the error.
************* Exception Text **************
System.IO.DirectoryNotFoundException: Could not find a part of the path '\\Desktop\SF_19-04-2013'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.Directory.InternalCreateDirectory(String fullPath, String path, DirectorySecurity dirSecurity)
at System.IO.Directory.CreateDirectory(String path, DirectorySecurity directorySecurity)
at System.IO.Directory.CreateDirectory(String path)
at SF_Diagnostic_Tool.Form1.Button1_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SF Diagnostic Tool
Assembly Version: 5.0.0.6
Win32 Version: 5.0.0.6
CodeBase: file:///C:/Users/dagbel/Desktop/SF_Diagnostic_Tool.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
2, I have given the default location %userprofile%\Desktop as the default location. If it's not accessible then the tool will not work. If it's not getting created that means the default locations in the registry is messed up.
19 Jun 2010   #1
derekimo
Excellent Capt., Nice work!
20 Jun 2010   #2
Capt.Jack Sparrow
Quote   Quote: Originally Posted by derekimo View Post
Thank You Derek !!
20 Jun 2010   #3
Product FRED
Windows 7 Enterprise 64-bit
Wow, amazing work!
20 Jun 2010   #4
Capt.Jack Sparrow
Quote   Quote: Originally Posted by Product FRED View Post
Wow, amazing work!
Thank You !!
20 Jun 2010   #5
Dinesh
Windows® 8 Pro (64-bit)
Good job Shyam.
20 Jun 2010   #6
Capt.Jack Sparrow
Quote   Quote: Originally Posted by Dinesh View Post
Good job Shyam.
Thank You Dinesh !!
20 Jun 2010   #7
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Another nice tool Cap'n, well done!
20 Jun 2010   #8
Capt.Jack Sparrow
Quote   Quote: Originally Posted by Bare Foot Kid View Post
Thank You Ted !!
20 Jun 2010   #9
theog
ME/XP/Vista/Win7
Nice tool,Captain.
SF Diagnostic Tool
Good Evening Folks: As per the instructions contained in the SF Diagnostic Tool, please find attached the results of the scan. Please note the Minidump scan reported that there was no file. Regards Powell Lucas
BSOD Help and Support
Is there a Mouse Diagnostic tool?
I have a Logitech MX300 with wireless 3 button mouse. The left, right and scroll wheel work fine, the center button doesn't seem to work at all. I have the latest version of SetPoint and tried setting it up with different key mappings but to no avail. I'm not even sure if it's working. Is...
Hardware & Devices
WMI Diagnostic Tool for 64-Bit
When I execute version 2.0 of the Microsoft's WMI Diagnostic Tool on my 64-bit Home Premium system, I get an 'Unsupported OS version or build #' error. Am I doing something wrong? If the tool doesn't work on 64-bit, is there a similar tool available which will? Thanks!
Software
memory diagnostic tool
does win 7's memory diagnostic tool always takes a long time from 21% to 22% on extended run? standard, short tests finish quickly i can run 2/3 tests in no time at all
Performance & Maintenance
SF Diagnostic Tool
SF Diagnostic Tool is to collect the information required to Analysis Blue Screen of Death and other troubleshooting purpose. Tool has been replaced with the GUI version http://www.sevenforums.com/tutorials/92394-using-sf-diagnostic-tool-troubleshooting.html Hope this helps, Captain
Crash and lockup debug 'How To'
