Windows 7: Power Plan - Restore Default Settings
29 Oct 2013   #10
HoneycombAG
I did that once, from the Recovery Console, up to 4 times from 4 different checkpoints, but it keeps getting me a failed (0x8000FFFF) message each time, but then I go back INTO Windows, then it says "System restore has completed successfully". I'm like WHAT?
Something is still broken with Windows. Maybe I didn't install a driver correctly?
29 Oct 2013   #11
Brink
64-bit Windows 10 Pro
For the 0x8000FFF error with System Restore, you might see if this may be able to help.
"E_UNEXPECTED 0x8000ffff" error when you try to restore a system by using System Recovery Options in Windows 7
30 Oct 2013   #12
HoneycombAG
Right, I tried to reinstall my motherboard drivers, then AMD Catalyst 13.9, then I disabled Avast Antivirus.
Tried "powercfg -restoredefaultschemes" again -- Now it says, "An unexpected error condition has occurred. Unable to perform operation. You may not have permission to perform this operation."
Issuing "powercfg -L" shows:
Existing Power Schemes (* Active)
Power Scheme GUID: 381b4222-f694-41f0-9685-ff5bb260df2e   *
30 Oct 2013   #13
Brink
As a test, log in to your built-in Administrator account to see if you are able to run the command in it.
Built-in Administrator Account - Enable or Disable
30 Oct 2013   #14
HoneycombAG
Now it's doing the same thing on my Windows 8.1 laptop, and I think I've got the gist of what's behind all of this.
Stupid avast hardened mode.
There is no command-line to reset all the default schemes FOR powercfg, and I had already made a custom scheme prior to upgrading to avast 2014. However, my laptop's display stayed bright until it was time for it to switch off, meaning it wouldn't dim down after e.g. 5 minutes, like it was set for. In fact, recently I had posted a short note on Facebook about it:
Quote:
I can't change my power management settings! What's the big idea?
And now it looks like I can't find the Dim display after setting. Imma have to uninstall the stupid AV.
30 Oct 2013   #15
Brink
That new feature in the new Avast sure has restricted/broken a lot of things.
31 Oct 2013   #16
HoneycombAG
I must be at the end of my rope. Had to reset my Dell laptop to factory defaults, because running sfc /scannow couldn't fix all of the damage that avast did. For some reason, however, installing Windows 8.1 causes me to lose the Dim display after controls, which is very discouraging, since the screen brightness impacts energy usage on battery power.
It's for that same reason that I have created a new account on Eight Forums.
31 Oct 2013   #17
Brink
Since it's an OEM PC, you might see if there may be a power management program that came preinstalled with it that may be overriding what you are setting in Windows.
31 Oct 2013   #18
HoneycombAG
I couldn't fix it. Sorry man.
There is a "Dell Extended Battery Life" option that puts my laptop to Power Saver when I unplug it. Unfortunately, that can't be removed from Programs and Features.
Looks like I'll have to leave avast 2014 off the computers for a while. Is it possible to install an old version or will it simply cause problems?
31 Oct 2013   #19
Brink
Not sure, but it appears that Avast 2014 is breaking quite a bit in Windows 8/8.1.
Comment
Tutorial Tools
Windows 7 Tutorial Category
Power Plan Settings - Change
How to Change Power Plan Settings in Windows 7 This will show you how to change the settings for the power plan that you have selected to reflect how you want your Windows 7 computer to manage power usage. Here's How: 1. Open the Start Menu, and type powercfg.cpl in the search...
Tutorials
Missing power state controls in advanced power plan settings
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is...
General Discussion
Power plan - do not keep settings!
Hi, I'm running Win7Pro 64bit in a Tecra R840 laptop. My power planning regarding LCD brightness is 40% if running on batery and 100% if plugged in. The problem is that, for some reason, I can't keep these settings and Windows (?) change it to 40% on batery and plugged in. Example: I...
Performance & Maintenance
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
Changing Default Power Plan
Hi , i cant be able to change default power plan (that will active on startup). I select a custom power plan but when restart it starts with . Can i change this ?
