Windows 7: Power Plan - Restore Default Settings
04 Nov 2013   #20
HoneycombAG
OK, now I'm ticked. Infuriated, I say!
I just now got an email back from Avast about this and they said, and I quote:
Quote:
This issue (Windows can't save some of your changes to this plan's power settings - Access is denied.) is not caused by avast! but by the absence of administration rights while making the changes.
Which means, prior to installing avast, I will have to activate the built-in Administrator account.
Unfortunately, the same thing happened there even in the built-in Administrator account:
I give up! I sent out a support package to the avast! team.
Comment
Tutorial Tools
Windows 7 Tutorial Category
Power Plan Settings - Change
How to Change Power Plan Settings in Windows 7 This will show you how to change the settings for the power plan that you have selected to reflect how you want your Windows 7 computer to manage power usage. Here's How: 1. Open the Start Menu, and type powercfg.cpl in the search...
Tutorials
Missing power state controls in advanced power plan settings
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is...
General Discussion
Power plan - do not keep settings!
Hi, I'm running Win7Pro 64bit in a Tecra R840 laptop. My power planning regarding LCD brightness is 40% if running on batery and 100% if plugged in. The problem is that, for some reason, I can't keep these settings and Windows (?) change it to 40% on batery and plugged in. Example: I...
Performance & Maintenance
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
Changing Default Power Plan
Hi , i cant be able to change default power plan (that will active on startup). I select a custom power plan but when restart it starts with . Can i change this ?
