Windows 7: Control Panel - Change Default Icon
13 Oct 2012   #10
Brink
64-bit Windows 10 Pro
Carl,
I just used OPTION TWO with your icon saved at the same location, and it's working fine for me after logging off and on.
Use step 2 in OPTION TWO to reset everything back to default, log off and on, and try OPTION TWO again double checking for any small possible mistake being made to see how it goes this time.
Control Panel - Change Default Icon-start_menu.jpg Control Panel - Change Default Icon-explorer.jpg
14 Oct 2012   #11
carlsjung
Yes! It worked this time. Perhaps something crashed when I logged out. For some reason my computer crashes when i log out. Thanks though!
14 Oct 2012   #12
Brink
Carl,
I'm happy to here that your Control Panel icon is changed to how you wanted now.
If you like, please create a new thread with any related details you can think of about your computer crashing when you log out, and we'll be happy to see what we may be able to do to help. It wouldn't hurt to see the link below, and include the report with the post to hopefully help with finding the cause.
http://www.sevenforums.com/crashes-d...tructions.html
15 Oct 2012   #13
carlsjung
It turns out that I only had a log off problem during the process of changing my icon. Now I can log off without the computer freezing.
15 Oct 2012   #14
Brink
Odd, but I'm glad to hear everything is fine now.
03 Apr 2014   #15
Eosim
Windows 7 Ultimate 32bit
First of all, really thanks for this tutorial.
I have just 2 problems with my custom control panel icon: first in the taskbar...there the icon showed is the default...i tried to change even the System.AppUserModel.RelaunchIconResource but without success.
The second problem is in the control panel; there in the address bar(or omnibox-i don't know the right name) the icon showed is my custom one with the category view but when i switch in the icons view(big and small) it return the default one.
Anyone can halp me?
03 Apr 2014   #16
Brink
Hello Eosim, and welcome to Seven Forums.
See if doing both OPTION ONE and OPTION TWO may sort this for you. Be sure to set the icon at all registry locations.
Hope this helps for now,
04 Apr 2014   #17
Eosim
Thank you for your answer, Brink.
Yesterday i changed all the default icon keys find in this tutorial, the 2 under CLSD and the other 2 under explorer and that was the outcome
Today i have change directly the icon in the imageres.dll (27) and the control.exe icon...but still have the dafault one in taskbar and in the address bar of control panel in the icons view (big and small)...maybe there is other files with that default control panel icon?
between sorry for my bad english
edit:
now is perfect...i just follow your guide Icon Cache - Rebuild and it work...before i just delete the iconchace manually under appdata\local...
Really thanks
04 Apr 2014   #18
Brink
Great news Eosim.
06 Jun 2015   #19
HP Win7 User
Windows 7 Professional x64 SP1
Hi Brink,
I was having some frustration trying to get the Control Panel icon to change. As it turns out, you have to replace the original path with your new icon in additional places in the registry, especially if you have a 64-bit Windows. I just found this out a few minutes ago by searching for imageres.dll,-27 throughout the registry and replacing it with my new icon.
I'm posting a list of places where Control Panel looks for its icons, which I found need to be updated to reflect the path of your icon. Turns out there are quite a few of them, if you're changing the value for all users (a dozen for 32-bit, plus 10 additional for 64-bit, makes 22 in total!), which makes me wonder if a find-and-replace program for the registry would be most helpful for this task.
Keys that I did not find in the original tutorial are highlighted in bold green. The full list is as follows:
32-bit all-users keys in HKEY_CLASSES_ROOT:
  • HKEY_CLASSES_ROOT\CLSID\{21EC2020-3AEA-1069-A2DD-08002B30309D}\DefaultIcon (is mentioned at this link)
  • HKEY_CLASSES_ROOT\CLSID\{26EE0668-A00A-44D7-9371-BEB064C98683}\DefaultIcon
  • HKEY_CLASSES_ROOT\CLSID\{328B0346-7EAF-4BBE-A479-7CB88A095F5B}\DefaultIcon
  • HKEY_CLASSES_ROOT\CLSID\{5399E694-6CE5-4D6C-8FCE-1D8870FDCBA0}\DefaultIcon
  • HKEY_CLASSES_ROOT\CLSID\{ED7BA470-8E54-465E-825C-99712043E01C}\DefaultIcon
64-bit all-users keys in HKEY_CLASSES_ROOT:
  • HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{21EC2020-3AEA-1069-A2DD-08002B30309D}\DefaultIcon
  • HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{26EE0668-A00A-44D7-9371-BEB064C98683}\DefaultIcon
  • HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{328B0346-7EAF-4BBE-A479-7CB88A095F5B}\DefaultIcon
  • HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{5399E694-6CE5-4D6C-8FCE-1D8870FDCBA0}\DefaultIcon
  • HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{ED7BA470-8E54-465E-825C-99712043E01C}\DefaultIcon
32-bit all-users keys in HKEY_LOCAL_MACHINE:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{21EC2020-3AEA-1069-A2DD-08002B30309D}\DefaultIcon
  • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{26EE0668-A00A-44D7-9371-BEB064C98683}\DefaultIcon
  • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{328B0346-7EAF-4BBE-A479-7CB88A095F5B}\DefaultIcon
  • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{5399E694-6CE5-4D6C-8FCE-1D8870FDCBA0}\DefaultIcon
  • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{ED7BA470-8E54-465E-825C-99712043E01C}\DefaultIcon
64-bit all-users keys in HKEY_LOCAL_MACHINE:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{21EC2020-3AEA-1069-A2DD-08002B30309D}\DefaultIcon
  • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{26EE0668-A00A-44D7-9371-BEB064C98683}\DefaultIcon
  • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{328B0346-7EAF-4BBE-A479-7CB88A095F5B}\DefaultIcon
  • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{5399E694-6CE5-4D6C-8FCE-1D8870FDCBA0}\DefaultIcon
  • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{ED7BA470-8E54-465E-825C-99712043E01C}\DefaultIcon
32-bit and 64-bit per-user keys in HKEY_CURRENT_USER (note there is no 64-bit per-user key by itself):
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CLSID\{26EE0668-A00A-44D7-9371-BEB064C98683}\DefaultIcon
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CLSID\{5399E694-6CE5-4D6C-8FCE-1D8870FDCBA0}\DefaultIcon
It is not necessary (and as I discovered, not possible) to change the value in the string:
which can be found under the keys
and
HKEY_CLASSES_ROOT\CLSID\{26EE0668-A00A-44D7-9371-BEB064C98683} (if on a 64-bit system).
Changing the string values in the rest of the keys works fine. At least it did for me, and I have proof:
Yes, Virginia, that is on a Windows 7 system!
Thanks to you, Brink, for the original tutorial. I couldn't have come this far without you.
cant see the the bluetooth icon anywhere in the control panel
hey ..i got a bluetooth dongle plugged it in ......shows under devices and printer in the control panel .....as device working properly and it says bluetooth radio in the categories ...the dongle also has a light blinking ......but i cant seem to find the bluetooth settings or bluetooth icon...
Hardware & Devices
Control Panel - Change Default Icons
How to Change Default Control Panel Icons in Windows 7 This will show you how to change the default icons in the All Control Panel Items small and large icons view to any custom icon that you want instead in Windows 7.You should use a 256x256 pixel .ico (icon) files to have the best...
Tutorials
RE : Troubleshooting icon in Control Panel
On this tutorial : http://www.sevenforums.com/tutorials/472-troubleshooting.html , there is a Troubleshooting icon in Control panel...... ????? ...
General Discussion
I have a icon in control panel & it does nothing.
I have a icon in control panel & it does nothing. After going to it has 56 items & control panel has 51 any ideas on how to find it I will start a new thread if you want me to Thanks Jerry
General Discussion
How to change the color of the top panel in control panel
Hi everyone, Today I realized that the text in the top panel of my control panel (as shown in the picture) is very difficult to read. I think one of the themes I installed changed the colors and I don't know how to get the colors changed back to what it used to be. So this got me wondering: how...
Themes and Styles
Control Panel - Default View
Windows 7. Control Panel. I have lost my default view of the Control Panel. The one that comes with Vista and Windows 7. Begins with Adjust your computers settings - then the first one is System and Security. Now all I have is the Classic View. I just installed Norton...
BSOD Help and Support
