Windows 7: Check Disk (chkdsk) - Read Event Viewer Log
04 Dec 2012   #50
Brink
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by sle3pingz View Post
yes i mean my HDD, safe right?
if clean or not, i scan with KIS 2013 Licensed can't?
Yes, you sure could.
04 Jan 2013   #51
itsmeena
Windows 7 Professional 32 bit
Perfect tutorial thanks man
04 Jan 2013   #52
Brink
Glad it could help itsmeena, and welcome to Seven Forums.
09 May 2013   #53
Camillia
Microsoft Windows 8 64-bit 9200 Multiprocessor Free
Thanks loads for your concise and clear tutorial. After trying to follow some guidance found on other websites and failing miserably, I found your easy steps and images. I have learned a lot just trying to make this post: how to download my system specs (the easy way, again, thanks to you and the person who developed the tool,and how to post an image from disk management which I tried to do right and will hopefully see here.
I have a win8 OS, I hope it is ok to post. I did the Chkdisk /f/r because of a couple critical errors I found on the event viewer one night which seemed to disappear the following morning. I could not find them event viewer. One I had saved to a file because I wanted to share it with Norton support. But it is no longer on the event viewer.
Searching the web I discovered that missing logs on the event viewer, could be a sign of HDD trouble, or malware. Doing a check disk was advised. I decided to do it because of the missing logs and other errors on the event viewer (boot degradation, and other stuff) which I can not pretend to understand. Funny, what prompts a novice to dive in over their heads. Otherwise my notebook runs fine, I think.
A question about the Disk Check results, the scan discovered and cleaned 1068 unused index entries. Because of the high number, should I be concerned? No bad sectors or bad files. Thanks for your work and help.
09 May 2013   #54
Brink
Hello Camillia, and welcome to Seven Forums.
I don't see any screenshots in your post.
If everything is running fine now, then I wouldn't be to concerned about it.
Logs could have also been deleted if you ran Disk Cleanup or some other 3rd party disk cleaning program (ex: CCleaner).
09 May 2013   #55
Camillia
Sorry, to make a second post just to include my attachments. I uploaded them for my previous (above) but they sat too long, over thirty minutes before clean up. This is what I believe happened after seeing the attachments did not work and rereading the tutorial how to post screenshots and files Here, are the attachments. Sorry, to disrupt the flow of the thread.
Check Disk Brink's Tutorial.txt
09 May 2013   #56
Brink
From your chkdsk log, you are fine since it had 0 KB in bad sectors.
09 May 2013   #57
Camillia
Hi Brink, Thank you for responding to my first post with the non working attachments. I was working on my second post (with working attachments) when you submitted your quick (impressive) reply.
I did not use a third party cleaner before loosing the files. But I did create and save two files from the event viewer without using any tool, like notepad. The two files are in my documents folder and they work like an actual event viewer. I can search other logs from the saved files. Perhaps these files, which I will delete, caused the missing logs from the event viewer program itself? I don't exactly remember how I created the files. I used the margin on the right side of the event viewer and pressed save selected events and copy. Maybe something else. Somehow, I managed to make a file but I do not believe the two I made are proper files because they appear as an active event viewer. I do not know how to relate this in tech terms, but maybe you can decipher.
Anyhow since you did not say that the 1068 unused index entries indicates a problem, I will not worry too much. It is exciting to learn about the hardware and OS. I will continue reading threads and trying things out. Let me know if what I shared about my event viewer files sheds any light on the missing event logs (one missing log is in my created file). Thank you for your tutorial, insight, and welcoming me to the forum.
09 May 2013   #58
Brink
You're welcome Camillia.
The unused index entries are nothing to worry about. It's just part of it's maintenance to clean them up.
15 Aug 2013   #59
JTSH
Windows Home 7
Brink, Help!
Hi Brink
I'm a total noob with regards to tech stuff and I really hope you can explain some things.
When I ran a chkdsk e: /f /r on my external hard disk, one of things which came up was "Deleting index entry ABC.DOC in index $I30 of file 5.'
Does this mean that chkdsk has deleted the file ABC.doc? If so how can i recover it?
If it was not deleted, then what does that mean essentially?
Sorry if the qn seems dumb but I only have the most basic computer related knowledge.
Wake Source - Read Event Viewer Log
How to Read the Wake Source Log in Event Viewer for Vista, Windows 7, and Windows 8 This will show you how to read the wake source log in the Event Viewer to see what device, task, or etc... has woke up your computer from sleep or hibernation at listed dates and times. You must be logged in...
Tutorials
Memory Diagnostics Tool - Read Event Viewer Log
How to Read Event Viewer Log for Windows Memory Diagnostics Tool This will show you how to read the Event Viewer log to see the results of the Windows Memory Diagnostics Tool in Vista, Windows 7, and Windows 8. If you just ran the Windows Memory Diagnostics Tool, then it may take a bit...
Tutorials
In Event Viewer, Where is event log for cleanmgr.exe (Disk Cleanup)?
I tried a lot, but couldn't find the event log for the cleanmgr.exe (Disk Cleanup) in the Event Viewer. Actually, I need the source & event id of cleanmgr.exe to schedule a task in the Task Scheduler. :confused:
Performance & Maintenance
CHKDSK - Event Viewer Doesn't Display Full Log
Checking file system on C: The type of the file system is NTFS. Volume label is CrossHair. A disk check has been scheduled. Windows will now check the disk. CHKDSK is verifying files (stage 1 of 5)... 364288 file records processed. ...
Locating chkdsk log in Event Viewer
Hi experts! :) If I were looking for the resultant log from chkdsk in the Event viewer on W7, which would I look for? Wininit or Winlogon? I thought Wininit was/is associated with XP and Winlogon for Vista and above? Thank you, Donna :geek:
Check disk failing, disk read errors, blue screen, computer going slow
As of late my PC has been going very slow, stuttering, freezing for a minute occasionally, and sometimes when I restart I get a disk read error that requires me to turn the PC off and on again. I ran check disk using command prompt, it got to 12% before it said it had found corrupt files, now it...
General Discussion
