Windows 7: Check Disk (chkdsk) - Read Event Viewer Log
How to Read the Event Viewer Log for Check Disk (chkdsk) in Vista, Windows 7, and Windows 8
Published by Brink
11 Jul 2010
information   Information
This will show you how to read the Event Viewer log to see the scan results of Check Disk (chkdsk) in Vista, Windows 7, and Windows 8.
Check Disk (chkdsk) - Read Event Viewer Log OPTION ONE Check Disk (chkdsk) - Read Event Viewer Log
To Read chkdsk Results Log Directly in Event Viewer
NOTE: You must be logged in as administrator to be able to open Event Viewer.
1. If you have not already, you will need to have ran Check Disk (chkdsk) in Vista/Windows 7 or Windows 8 prior before it will be in the Event Viewer System log.
2. Press the Windows + R keys to open the Run dialog, type eventvwr.msc, and press Enter.
3. If prompted by UAC, then click on Yes (Windows 7/8) or Continue (Vista).
4. In the left pane of Event Viewer, double click on Windows Logs to expand it, click on Application to select it, then right click on Application and click on Find. (see screenshot below)
5. Copy and paste Chkdsk into the line, and click on Find Next. (see screenshot below)
NOTE: You can continue to click on Find Next to search for other older application logs (if available) for Check Disk (chkdsk) to see them as well.
6. You will now see the system log for the scan results of Check Disk (chkdsk). (see screenshot below)
NOTE: The log will have the Chkdsk tag if Check Disk is ran only from within Windows.
7. Go back to the top of the log file list in the middle pane of Event Viewer, then copy and paste Wininit into the line, and click on Find Next. (see screenshot below step 5)
8. You will now see the system log for the scan results of Check Disk (Wininit). (see screenshot below)
NOTE: The log will have the Wininit tag if the computer has to restart to run Check Disk at startup instead of within Windows.
9. When finished searching for Check Disk (chkdsk) application logs, you can close the Find window. (see screenshot below step 5)
10. When finished, you can close Event Viewer.
Check Disk (chkdsk) - Read Event Viewer Log OPTION TWO Check Disk (chkdsk) - Read Event Viewer Log
To Create .txt file on Desktop with chkdsk Results Log
Note   Note
This option is not available in Vista.
1. Press the Windows + R keys to open the Run dialog, type powershell.exe, and press Enter.
2. In PowerShell, copy and paste the command below, and press Enter. (see screenshot below)
NOTE: To paste the copied command into PowerShell, you will just need to right click in PowerShell.
get-winevent -FilterHashTable @{logname="Application"; id="1001"}| ?{$_.providername –match "wininit"} | fl timecreated, message | out-file Desktop\CHKDSKResults.txt
3. You will now have a CHKDSKResults.txt file created on your desktop that is the log file of your chkdsk scan results from Event Viewer.
12 Jul 2010   #1
theog
ME/XP/Vista/Win7
Hi Shawn
Very nice tutorial, Shawn.
Just a thought, may be you could update the Disk Check tutorial to include Command Prompt as in Check Disk tutorial Vista x64forum.
Ray.
12 Jul 2010   #2
Brink
64-bit Windows 10 Pro
Hello Ray,
I shall add the command prompt option tonight.
UPDATE:
It has now been added.
Disk Check
13 Jul 2010   #3
theog
ME/XP/Vista/Win7
Looks great.
13 Jul 2010   #4
Brink
Thank you.
02 May 2011   #5
ICIT2LOL
Brilliant
Hey Brink you're a legend mate I have been trying to find out 1) how to read the event viewer and 2) what my chkdsk's have come up with.
My local forum doesn't have such brilliant tutorials laid out like this format and I am one of those who need either an analogy or something like this to get it into the little bit of grey matter that's left you make it look so easy for silly old buggas like me
02 May 2011   #6
Brink
Thank you for the kind words John. It's always great to know that the tutorials are helpful for everyone.
15 Sep 2011   #7
Onclejean
Win 7 Ultimate SP1
Thanks for the tutorial. It enables me to illustrate but not solve my problem. The log found is
CHKDSK is verifying files (stage 1 of 3)...
207616 file records processed. File verification completed.
185 large file records processed. 0 bad file records processed. 2 EA records processed. 109 reparse records processed. CHKDSK is verifying indexes (stage 2 of 3)...
283042 index entries processed. Index verification completed.
CHKDSK is scanning unindexed files for reconnect to their original directory.
Recovering orphaned file Chkdsk20110703093010.log (68213) into directory file 68197.
Recovering orphaned file Chkdsk20110709165629.log (68214) into directory file 68197.
Recovering orphaned file Chkdsk20110714133433.log (68215) into directory file 68197.
Recovering orphaned file Chkdsk20110722172351.log (68216) into directory file 68197.
Recovering orphaned file Chkdsk20110722173123.log (68217) into directory file 68197.
Recovering orphaned file Chkdsk20110725194533.log (68218) into directory file 68197.
Recovering orphaned file Chkdsk20110727084051.log (68219) into directory file 68197.
Recovering orphaned file Chkdsk20110727120925.log (68220) into directory file 68197.
Recovering orphaned file Chkdsk20110805083128.log (77448) into directory file 68197.
10 unindexed files scanned. Recovering orphaned file Chkdsk20110806090816.log (77450) into directory file 68197.
Unfortunately I cannot find file directory 68197: and when I run chkdsk again at the next boot chkds does the same thing. So I conclude it is NOT infact clearing the orphans. What more should I do or just leave it?
15 Sep 2011   #8
Brink
Hello John,
With it saying 0 bad file records processed., I would not worry about it.
07 Dec 2011   #9
dbdb
Wundows 7 Home Premium 64
Yes but it is very annoying I have the same problem. I suspect Casper as the drive was cloned and re-created using Casper when the errors started appearing. Thye always relate to Chkdskxxx.log files.
Wake Source - Read Event Viewer Log
How to Read the Wake Source Log in Event Viewer for Vista, Windows 7, and Windows 8 This will show you how to read the wake source log in the Event Viewer to see what device, task, or etc... has woke up your computer from sleep or hibernation at listed dates and times. You must be logged in...
Tutorials
Memory Diagnostics Tool - Read Event Viewer Log
How to Read Event Viewer Log for Windows Memory Diagnostics Tool This will show you how to read the Event Viewer log to see the results of the Windows Memory Diagnostics Tool in Vista, Windows 7, and Windows 8. If you just ran the Windows Memory Diagnostics Tool, then it may take a bit...
Tutorials
In Event Viewer, Where is event log for cleanmgr.exe (Disk Cleanup)?
I tried a lot, but couldn't find the event log for the cleanmgr.exe (Disk Cleanup) in the Event Viewer. Actually, I need the source & event id of cleanmgr.exe to schedule a task in the Task Scheduler. :confused:
Performance & Maintenance
CHKDSK - Event Viewer Doesn't Display Full Log
Checking file system on C: The type of the file system is NTFS. Volume label is CrossHair. A disk check has been scheduled. Windows will now check the disk. CHKDSK is verifying files (stage 1 of 5)... 364288 file records processed. ...
Locating chkdsk log in Event Viewer
Hi experts! :) If I were looking for the resultant log from chkdsk in the Event viewer on W7, which would I look for? Wininit or Winlogon? I thought Wininit was/is associated with XP and Winlogon for Vista and above? Thank you, Donna :geek:
Check disk failing, disk read errors, blue screen, computer going slow
As of late my PC has been going very slow, stuttering, freezing for a minute occasionally, and sometimes when I restart I get a disk read error that requires me to turn the PC off and on again. I ran check disk using command prompt, it got to 12% before it said it had found corrupt files, now it...
General Discussion
