Screenshot with Paint
Page 1 of 3 123 LastLast
    How to Take and Create a Screenshot with Paint in Windows 7
    This will show you how to take a full screen screenshot or a single window screenshot, then create and save the screenshot in Windows 7 Paint.
       Tip
    If you wanted to take a screenshot of a opened menu item, then you would want to use step 1 and crop the screenshot in Paint since the menu item would close when trying to take the screenshot with step 2.
    Here's How:
    1. To Take a Screenshot of the Entire Display Screen
    NOTE: If you have multiple monitors, then they will also be included in the full screen screenshot. This option will also include context menus in the screenshot.
    A) Press the PrtScn key for a desktop.
    NOTE: For laptops or notebooks, you may need to press either the Ctrl+PrtScn or Fn+PrtScn keys instead of only the PrtScn key.
    B) Go to step 3.
    2. To Take a Screenshot of only the "Active" Window
    NOTE: This will just be a screenshot of the window that you have the focus set on. The window that has focus will have a darker border than the other opened windows.
    A) Click on the title bar of the window that you want to take a screenshot of to place focus on it.
    B) Press the Alt+PrtScn keys for a desktop.
    NOTE: For laptops or notebooks, you may need to press the Alt+Fn+PrtScn keys instead of only the Alt+PrtScn key.
    3. Open Paint.
    4. In Paint, press Ctrl+V to paste the screenshot into Paint.
    A) Go to step 6.
    OR
    5. In Paint, click on the rectangle above Select on the toolbar, then right click on the white space in the lower main pane of Paint and click on Paste. (See screenshot below)
    6. Make any crops or adjustments you would like to the screenshot. (See screenshots below)
    NOTE: For detailed information on how to use Paint, click on the icon at the upper right corner in Paint. The left screenshot is of a single window, and the right screenshot is of the full screen.
    7. When ready to save the screenshot, click on the file drop down arrow to the left of the Home and View tab. Next, hover the mouse pointer on Save as to open it, then click on the file extension (ex: JPEG) that you want to save the screenshot as. (See screenshot below)
    8. Navigate to where you want to save the screenshot. Type in a name for the screenshot to be saved as, and click on the Save button. (See screenshot below)
    9. When done taking screenshots, close Paint.
  1. Posts : 12,177
    Nice tut,
    Will this work in any graphics program?
    Tried it in Paint.net and it worked.
  2. Posts : 6,305
    Dave76 said:
    Nice tut,
    It will work with any paint package that's capable of pasting the clipboard as a new image :)
  3. Posts : 4,573
    I still use this old school trick to capture transient screen images like tool-tips. The snipping tool will take system focus and some dialog boxes will disappear. PrintScreen/Paste is a very good thing to know (remember).
  4. Posts : 12,177
    Possibly add the Snipping Tool?
  5. Posts : 72,014
    Hi Dave,
    I thought about it, but with the Snipping Tool, you cannot take screenshots of open menu items as Antman posted above though. I wanted to make it usable in all cases.
  6. Posts : 4
    Windows 7 Professional x64
    Oh wow, you do learn something new everyday!
    Didn't know about the Alt + Prt Sc trick! Thanks a lot Brink!
  7. Posts : 72,014
    You're welcome Krazywrath, and welcome to Seven Forums. :)
  8. aem
    Windows 7 Ultimate 64Bit
    Hi Brink, is it ok to write a tut using a separate utility for snap shooting images?
  9. Posts : 72,014
    Hello AEM,
    Sure, as long as it's not a program that must be purchased to use it. You might also double check in the Tutorial index to make sure that we do not already have one for it as well. :)
