Windows 7: SF IE Restorator - Troubleshooting General Issues with IE
25 Jul 2010   #10
ericpeacock79
XP, 7
Totally Awesome!
Thanx!
This will be used A LOT!
Thank you! Thank you!Thank you!Thank you!
09 Aug 2010   #11
Colorancher
Win 7
Nice. Thanks. I seemed to have random lockups. Not Win7 just IE8. And it doesn't show up in add/remove programs so I couldn't reload it.
11 Aug 2010   #12
TIGERsHAKER
xp
thanks man of course going to give it a try : )
23 Sep 2010   #13
navjotjsingh
Windows 7 Ultimate x32
What about IE9? Is it compatible with IE9 also?
12 Feb 2013   #14
xunderworldx
This helped a lot, I was having problems with Internet Explorer not allowing any windows media player content to stream. It was missing protocols under Network > Streaming Proxy Settings.. After resetting everything & restarting everything worked again!
Hope this will help others like my self solve this problem!
29 Feb 2016   #15
freshhh
W10 x64
could you please update this tool for W10 x64 & IE11 x64 ? thanks!
27 Sep 2016   #16
freshhh
W10 x64
* bump *
Tips on Troubleshooting Game Issues
Please note this is a guide for troubleshooting game issues. It is not a thread to fixing those issues. You'll need to create a seperate thread for your own game issue. ==================================================== We see lots posts about problems with games that won’t run, have bad...
Gaming
System Restore General Troubleshooting to Fix Issues
General Troubleshooting to Fix System Restore Issues If the System is not able to create System restore point try to Create the restore point manually. If you are unable to create a system restore point manually then you could try these steps 1. Make sure that System Restore is enabled 2....
Tutorials
Troubleshooting Severe Latency Issues
I am having issues with latency on my computer (Windows 7 64bit, 2.2 GHz, 6 GB RAM). I initially tried to do some research myself to resolve the issue. I stumbled upon this site: DPC Latency Checker and I then followed the instructions on that page. I tried to isolate all network drivers...
Troubleshooting Explorer.exe Crashing Issues
Troubleshooting Explorer.exe Crashing Issues I have seen lot of scenarios where users posting Explorer.exe crashing or stopped working issues. After troubleshooting lot of issues I'm posting here some common fixes that might help. 1. Most of the times the Explorer crashes due a bad...
Crash and lockup debug 'How To'
Outlook - General Troubleshooting Guide for Issues
General Troubleshooting Guide For Issues with Microsoft Outlook These are some General troubleshooting steps to fix Outlook issues like unable to open or crashing while doing something in Outlook etc. 1. Start up problem of Outlook This is one of the most common problems with...
Tutorials
General Troubleshooting to Fix WMP Issues
Windows 7 has some fine in-built diagnostic tools to help you trouble-shoot Windows Media Player issues, which you may be facing. To open these specific troubleshooting & diagnostic modules do the following: Type msdt.exe -id WindowsMediaPlayerConfigurationDiagnostic in Start Search...
Music, Pictures & Video
