Windows 7: SF IE Restorator - Troubleshooting General Issues with IE
Published by Capt.Jack Sparrow
17 Jul 2010
SF IE Restorator - Troubleshooting General Issues with Internet Explorer
information   Information
This is small utility for Troubleshooting Internet Explorer issues. It will Flush DNS, Re-register concern dlls for Internet Explorer (3 different types 64-Bit, 32 Bit on 64-Bit OS and 32-Bit) Reset IE to Default settings, Reset Winsock.
SF IE Restorator will work with Internet Explorer in Windows 7. It will work with other operating system only if you have .NET Frameworks 3.5 installed.
warning   Warning
Some Antivirus / Firewall might detect SF IE Restorator Tool is Trojan its just a False positive because the publisher is unknown. Nothing to worry it won't harm your Computer
Screenshot
Note: Make sure when you open the application your Right Click on the icon and click Run as administrator.
Flush / Review DNS IP:
Most DNS clients cache the results of name resolution requests. This means that the DNS clients will temporarily store the website names that you have been visiting lately. This process speeds up name resolution if multiple lookups are done to the same address, such as is common when browsing the web. Hence, if you visit Yahoo.com second time, the DNS client will already have the name mapped and hence will retrieve the mapping quickly. Sometimes a bad DNS entry will be cached and you will need to either flush the DNS cache to get rid of it.
Re-register IE: There are collections of routines that are stored until a program uses them. If these files are corrupt or out of date, they can cause problems with your computer. To fix this problem, re-register the .dll files.
Reset IE: If the problem is caused by damaged or incompatible Internet Explorer settings or add-ons, you can usually resolve the problem by resetting Internet Explorer settings.
Reset Winsock: Most of the Internet connectivity problems arise out of corrupt Winsock settings. Windows sockets settings may get corrupted due to the installation of a networking software, or perhaps due to Malware infestation. You will be able connect to the Internet, but the packets won't transfer back and forth. Resetting Winsock might fix the issue.
WARNING: Before running the Reset Winsock make sure you close all applications first since it will restart the computer.
Download the application:
download
Captain
17 Jul 2010   #1
derekimo
Nice work Capt.
17 Jul 2010   #2
Capt.Jack Sparrow
Quote   Quote: Originally Posted by derekimo View Post
Nice work Capt.
Thank You Derek !
17 Jul 2010   #3
A Guy
Had it on my PC since I tested it. Well done Capt.
A Guy
17 Jul 2010   #4
TimStitt
Windows 7 Ultimate 64 bit
Nice work Capt!
17 Jul 2010   #5
Capt.Jack Sparrow
Quote   Quote: Originally Posted by TimStitt View Post
Nice work Capt!
Thanks Timo !!
17 Jul 2010   #6
Capt.Jack Sparrow
Quote   Quote: Originally Posted by A Guy View Post
A Guy
Thanks A Guy !
19 Jul 2010   #7
Dave76
Nice tut and tool, thanks Capt,
22 Jul 2010   #8
usasma
Microsoft MVP
22 Jul 2010   #9
Capt.Jack Sparrow
Quote   Quote: Originally Posted by usasma View Post
Thanks John !
Tips on Troubleshooting Game Issues
Please note this is a guide for troubleshooting game issues. It is not a thread to fixing those issues. You'll need to create a seperate thread for your own game issue. ==================================================== We see lots posts about problems with games that won’t run, have bad...
Gaming
System Restore General Troubleshooting to Fix Issues
General Troubleshooting to Fix System Restore Issues If the System is not able to create System restore point try to Create the restore point manually. If you are unable to create a system restore point manually then you could try these steps 1. Make sure that System Restore is enabled 2....
Tutorials
Troubleshooting Severe Latency Issues
I am having issues with latency on my computer (Windows 7 64bit, 2.2 GHz, 6 GB RAM). I initially tried to do some research myself to resolve the issue. I stumbled upon this site: DPC Latency Checker and I then followed the instructions on that page. I tried to isolate all network drivers...
Troubleshooting Explorer.exe Crashing Issues
Troubleshooting Explorer.exe Crashing Issues I have seen lot of scenarios where users posting Explorer.exe crashing or stopped working issues. After troubleshooting lot of issues I'm posting here some common fixes that might help. 1. Most of the times the Explorer crashes due a bad...
Crash and lockup debug 'How To'
Outlook - General Troubleshooting Guide for Issues
General Troubleshooting Guide For Issues with Microsoft Outlook These are some General troubleshooting steps to fix Outlook issues like unable to open or crashing while doing something in Outlook etc. 1. Start up problem of Outlook This is one of the most common problems with...
Tutorials
General Troubleshooting to Fix WMP Issues
Windows 7 has some fine in-built diagnostic tools to help you trouble-shoot Windows Media Player issues, which you may be facing. To open these specific troubleshooting & diagnostic modules do the following: Type msdt.exe -id WindowsMediaPlayerConfigurationDiagnostic in Start Search...
Music, Pictures & Video
