Windows 7: Shutdown Problem when Power On Virtual Machine
16 Jun 2016   #11
Botard
Windows 7 Ultimate 64bit
NO, I don't want overclocking the cpu.
Here's the pdf file log's result, please let me know if this is what you need.
Again, opening prime95 shut off the windows.
16 Jun 2016   #12
townsbg
Windows 7 pro 64-bit
Did you look at that? It only has seconds not temps.
04 Aug 2016   #13
Botard
Townsbg, how are you today.
been busy that time the reason I didn't response to you. Until then, I noticed my hard drive not fully working. Now I got a replace from my laptop hard drive spare. So far, I got no issue only the transfer rate is slower than the one hdd I replaced. I still used it as back up saving drive temporarily while looking an almost brand-new drive but the cheapest.
What do you think that noise in the drive is the reason this pc got the issue?
04 Aug 2016   #14
townsbg
It depends upon the noise. It could simply be that the hard drive was being read from or it could have been a sign of hard drive failure. As for a change in transfer speed, that could happen if you replaced the drive with one of a lower rpm.
04 Aug 2016   #15
Botard
Okay, I strongly believe and being hopeful this time my pc is going back to normal. About this hard drive failing, I reformatted it then checked disk to recover bad sectors, and it always found some problems but fixed the windows. So I reattached it to have a second hard drive, to use its life span this one terabytes lame drive.
04 Aug 2016   #16
townsbg
Windows can't fix bad sectors caused by physical problems with the drive. It can only possibly fix problems with the filesystem.
05 Aug 2016   #17
Botard
Have you experience repairing a drive? I really want to try a repair but the book of Mike Meyers' computer skills (2006) wrote not to open the drive and should replace a new one. I have here not seeing the bios but the platter is still rotating.
I was thinking this idea to try when I saw a bunch of defect hard drive posted for sale, 4.5$ each. I don't know other reason why they sell it if hdd is not repairable.
05 Aug 2016   #18
townsbg
Hard drives are generally only repairable by the manufacturer or experts. It is more cost effective to replace the drive unless it is still under warranty. Depending upon the problem the drive might not be repairable.
29 Aug 2016   #19
Botard
For one month observation I found no problem after replacing the hdd, so I think the issue here was solved... Thanks the forum!
Search this Thread:
Advanced Search
Problem installing XP on Virtual machine windows 7
I'm running W7 Home and have installed Oracle Virtual machine on which I want to install XP. But when I try installing XP the option 'Install' is greyed out. I've tried increasing the HD size (20GB) of the virtual machine but with the same result. The reason I'm doing all this is because I must...
Virtualization
Windows XP Virtual Machine USB attach problem
I have Win 7 Professional x64, and whenever I attach a USB device (my mp3 player, to update its firmware), it installs the drivers needed, then after about 30 seconds automatically detaches (that is, it is shared and auto-reattaches to Windows 7). I have uninstalled and then reinstalled XP mode,...
Virtualization
Development Programming in Virtual Machine vs Host Machine
Hi guys, I have been around this problem for some time now and want to know you opinions. I am running on HP notebook: Intel Core 2 Duo 2.26GHz, 64bit Windows 7 Professional, 4GB Ram, ATI Graphics. I want to ask your opinions about doing developments, is it better to be in the host...
Virtualization
Problem with thumb drive after exiting virtual machine
The operating system on my desktop is Windows 7 Home Premium 64 bit. Today I installed VMware and then installed Windows XP in the virtual machine. I'm having a problem concerning my USB thumb drive. I am able to use the thumb drive in the guest machine and I think that I am disconnecting it when I...
Virtualization
XP Virtual machine and CD/DVD problem
Hi all running a Virtual XP with vmware and build 7137 -- if you need to change a DVD/CD Windows doesn't refresh the data / directories unless you choose EJECT in the context menu. Just unloading and reloading a new CD doesn't seem to work. Can be a problem if installing a product which...
Virtualization
RC1 XP Virtual Machine Problem
Hi, I am using 64bit RC1 and everything was fine until I installed the XP Virtual Machine, after I've installed it, I got BSOD with following message: A clock interrupt was not received on a secondary processor within the allocated time interval :(
Virtualization
