Windows 7: Shutdown Problem when Power On Virtual Machine
12 Jun 2016   #1
Botard
Windows 7 Ultimate 64bit
I don't understand the problem every time I powered on the virtual machine the host was shutdown?
12 Jun 2016   #2
townsbg
Windows 7 pro 64-bit
Please explain more about what is going on and tell us what you are doing.
13 Jun 2016   #3
Botard
My pc is good a windows 7 64 bit, no problem when using it alone but powering virtual machine on, the host will shutdown. Totally shutdown the screen went black no power like pulling out the power cord in an outlet accidentally. Oh man, I don't really know what is going on the program. There are times I can use the virtual machine for several minutes while other a few minutes before shutdown.
I tried to look a solution on internet but no specific or a direct answer to my problem. There's no program installed in virtual machine environment. The VMware is a 64bit. One thing in my mind is the host bios, does it need to configure before installing VMware?
Thanks for the attention.
14 Jun 2016   #4
Botard
Update, it also shutdown in the host without powering the virtual machine, I have doubt either the physical drive or the power supply.
15 Jun 2016   #5
townsbg
With a random shutdown your problem is likely either the power supply or the cpu is overheating. It would be different if you are getting blue screens or freezes. Please confirm that you are only getting a shutdown. How have you ruled out the PSU? The next step would be to install speed fan to monitor your cpu temps. SpeedFan - Access temperature sensor in your computer
After you install that install prime95 to stress test your cpu. Watch the temps and turn off prime95 if the temp gets over 60C. GIMPS - Free Prime95 software downloads - PrimeNet
With this happening outside of vmware then your issue isn't with vmware and to answer your question there shouldn't be any bios configurations required for vmware.
15 Jun 2016   #6
Botard
Yes only shutdown for now as it also freeze before with some insect noise alike I heard in my drive but this was fixed several times by unplug the cord back and forth in physical drive. Freezes happen when the system unit inside is touched or when I cleaned it.
A while ago I just installed the game in cd drive the first cd was successful but the second one at the middle process was shutdown the host. Then I power on the pc and log on windows password, a few minutes while clicking windows explorer, it happen again. So far, the pc is doing fine and I uninstall the game and deleting manually considering my pc is very sensitive now.
About CPU, is it matter the thermal paste I used because I bought it and didn't know if it work properly or having a brand name not recommended by motherboard manufacturer?
15 Jun 2016   #7
Botard
What is wrong with this pc? I installed the speed fan and ran it, then the free prime95. When I opened free prime95 and select stress test the pc shutdown twice same at selecting stress test again.
15 Jun 2016   #8
townsbg
Your cpu looks like it is burning a little high but not enough to cause a shutdown. Is that while running prime95? What does it get to when prime95 is running? As for thermal compound I used a silver based paste-it is better than the paste that comes with the cpu. I don't know how much you used but you only put a thin layer. You only need to put enough to cover the cpu. Too much and it doesn't work. Also make sure that the heat sink is cleaned out. Every now and then I had to remove the fan off of the heat sink to get all of the dust off. Dust also prevents heat dissipation.
15 Jun 2016   #9
Botard
It seems my system cannot handle selecting the stress test in prime95 or any program that might trigger to shut-off the windows.
I took the image above after shut the windows off twice when running prime95. There's no other doing in my system when running prime95 except the system was off randomly. So, I didn't had a chance to snip it like I did the speedfan image.
Ok, for your advice for dust removing, I'll follow it and I'm going to use this speedfan to monitor the temperature whether the heat properly sink, later on after I figure out the issue.
16 Jun 2016   #10
townsbg
You haven't told me how hot it gets. You can set speedfan to log it's results. That way even if it shuts off you still have a record of what was happening at the time. Please do so and try prime95 again and upload the log. All you need to select to log are the temps. I don't care about anything else. Do you overclock?
Search this Thread:
Advanced Search
Problem installing XP on Virtual machine windows 7
I'm running W7 Home and have installed Oracle Virtual machine on which I want to install XP. But when I try installing XP the option 'Install' is greyed out. I've tried increasing the HD size (20GB) of the virtual machine but with the same result. The reason I'm doing all this is because I must...
Virtualization
Windows XP Virtual Machine USB attach problem
I have Win 7 Professional x64, and whenever I attach a USB device (my mp3 player, to update its firmware), it installs the drivers needed, then after about 30 seconds automatically detaches (that is, it is shared and auto-reattaches to Windows 7). I have uninstalled and then reinstalled XP mode,...
Virtualization
Development Programming in Virtual Machine vs Host Machine
Hi guys, I have been around this problem for some time now and want to know you opinions. I am running on HP notebook: Intel Core 2 Duo 2.26GHz, 64bit Windows 7 Professional, 4GB Ram, ATI Graphics. I want to ask your opinions about doing developments, is it better to be in the host...
Virtualization
Problem with thumb drive after exiting virtual machine
The operating system on my desktop is Windows 7 Home Premium 64 bit. Today I installed VMware and then installed Windows XP in the virtual machine. I'm having a problem concerning my USB thumb drive. I am able to use the thumb drive in the guest machine and I think that I am disconnecting it when I...
Virtualization
XP Virtual machine and CD/DVD problem
Hi all running a Virtual XP with vmware and build 7137 -- if you need to change a DVD/CD Windows doesn't refresh the data / directories unless you choose EJECT in the context menu. Just unloading and reloading a new CD doesn't seem to work. Can be a problem if installing a product which...
Virtualization
RC1 XP Virtual Machine Problem
Hi, I am using 64bit RC1 and everything was fine until I installed the XP Virtual Machine, after I've installed it, I got BSOD with following message: A clock interrupt was not received on a secondary processor within the allocated time interval :(
Virtualization
