BSODs, Have already RMA'd a few parts.
Page 1 of 5 123 ... LastLast
  1. Posts : 25
    Windows 7 Professional 64bit
    I am using window 7 Professional 64 bit edition. I put this new system together and have been getting a few different BSODs ever since putting it together. Here are the specs:
    Corsair 750 watt power supply
    XFX Radeon HD 5770
    AMD Phenom II x4 965 Black Edition
    MSI 870A-G54 Motherboard
    Corsair XMS 4GB DDR3
    I attached the dump files but I get getting BSODs for random things, sometimes its in the middle of a game, other times it's simply when I'm browsing the internet. I have already reinstalled windows multiple times as well as RMA'd my video card and processor. I ran memtestx86 for a few nights and there were no errors. Since I just reinstalled windows, all the drivers I do believe are up to date and there are almost no other programs installed. Please let me know if I left any information out. Thanks!
  2. Posts : 507
    Your dumps have error code:
    - 0x50 = that invalid system memory (could be RAM or driver)
    - 0xF4 = system operation has unexpectedly exited or been terminated.
    You have memory corruption issue so perform memory test for at least 7 passes.
    RAM - Test with Memtest86+
    BugCheck 50, {fffffa801235299b, 0, fffff80002a8cd3b, 2}
    Could not read faulting driver name
    Probably caused by : memory_corruption ( nt!MiAgeWorkingSet+41b )
    Uninstall Alcohol/Daemon and remove its driver with Sptdinst.
    You could re install that software later after your system stable.
    The worse thing is your performance report indicated: CPU, Graphic, Disk, and Memory are in the poor performance.
    Maybe there is something wrong with your motherboard.
    Log
    *                        Bugcheck Analysis                                    *
    Use !analyze -v to get detailed debugging information.
    BugCheck F4, {3, fffffa800521cb30, fffffa800521ce10, fffff800029d4240}
    Probably caused by : csrss.exe
    Followup: MachineOwner
    0: kd> !analyze -v
    CRITICAL_OBJECT_TERMINATION (f4)
    A process or thread crucial to system operation has unexpectedly exited or been
    terminated.
    Several processes and threads are necessary for the operation of the
    system; when they are terminated (for any reason), the system can no
    longer function.
    Arguments:
    Arg1: 0000000000000003, Process
    Arg2: fffffa800521cb30, Terminating object
    Arg3: fffffa800521ce10, Process image file name
    Arg4: fffff800029d4240, Explanatory message (ascii)
    Debugging Details:
    PROCESS_OBJECT: fffffa800521cb30
    IMAGE_NAME:  csrss.exe
    DEBUG_FLR_IMAGE_TIMESTAMP:  0
    MODULE_NAME: csrss
    FAULTING_MODULE: 0000000000000000
    PROCESS_NAME:  csrss.exe
    EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
    BUGCHECK_STR:  0xF4_C0000005
    CUSTOMER_CRASH_COUNT:  1
    DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
    CURRENT_IRQL:  0
    STACK_TEXT:
    fffff880`03accb08 fffff800`02a57142 : 00000000`000000f4 00000000`00000003 fffffa80`0521cb30 fffffa80`0521ce10 : nt!KeBugCheckEx
    fffff880`03accb10 fffff800`02a03269 : ffffffff`ffffffff fffffa80`055deb60 fffffa80`0521cb30 fffffa80`0521cb30 : nt!PspCatchCriticalBreak+0x92
    fffff880`03accb50 fffff800`02987c74 : ffffffff`ffffffff 00000000`00000001 fffffa80`0521cb30 00000000`00000008 : nt! ?? ::NNGAKEGL::`string'+0x17a06
    fffff880`03accba0 fffff800`026cb153 : fffffa80`0521cb30 fffff880`c0000005 fffffa80`055deb60 fffffa80`05bc5060 : nt!NtTerminateProcess+0xf4
    fffff880`03accc20 00000000`772d017a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
    00000000`0083e768 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x772d017a
    STACK_COMMAND:  kb
    FOLLOWUP_NAME:  MachineOwner
    FAILURE_BUCKET_ID:  X64_0xF4_C0000005_IMAGE_csrss.exe
  3. Posts : 25
    I already ran through 11 passes of memtest86 just today and prior to today have also ran through many more passes with 0 errors. Do you think it'll be best to simply RMA the motherboard? I don't see why everything would be in poor performance, all the parts are brand new. Thanks for the quick response!
  4. Posts : 185
    Windows 7 Ultimate 32bit
    I'd say try reseting the cmos, run a good C-clean - CCleaner - Free software downloads and software reviews - CNET Download.com - And finally chkdsk to make sure..Swap ram around,,maybe a few new SATA's or IDE's(Cables) Run this program to view Temps..(In Degrees) and all other system info in detail.. Download SIW 2010 Build 0714 Free - Displays information about Operating System, Installed Program etc - Softpedia
    Also run a good graphical test to view the speeds and temps - FurMark 1.8.0 Hot Like Hell Edition Available - 3D Tech News, Pixel Hacking, Data Visualization and 3D Programming - Geeks3D.com Let us know the stats you pull--
  5. Posts : 507
    The possibilities of memory corruption :
    - Bad RAM
    - Mismatch of RAM sticks
    - Bad slots motherboard
    So you must try memtest each stick individually and with different slot.
    And you may also test CPU and RAM with prime95 --> Blend test
    Because sometimes memory error not detected in memtest but not for prime95 test. (and vice versa so it's better to try both of them)
    https://www.sevenforums.com/tutorials...t-prime95.html
    Here is your System Diagnostics Report (Computer GGLOL-PC) :
    • The "CPU" rating for the system is poor and may be the cause of performance problems.
    • The "Gaming graphics" rating for the system is poor and may be the cause of performance problems in multimedia applications or games.
    • The "Graphics" rating for the system is poor and may be the cause of performance problems.
    • The "Disk" rating for the system is poor and may be the cause of performance problems.
  6. Posts : 13,354
    Windows 7 Professional x64
    Memory corruption can also be caused by drivers.
    I see SPTD installed:
    sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
    You have Daemon Tools Lite installed -- that is what is using SPTD.
    Remove Daemon, and then remove SPTD. Use this tool: http://www.duplexsecure.com/download...t-v174-x64.exe
    SPTD causes all kinds of strange errors, including 0x124 BSODs.
    Wish mentioned a poor disk rating. I have seen BSODs very similar to yours, caused by a bad hard drive. Test the drive with Data Lifeguard tools: WD Support > Downloads > SATA & SAS > WD Caviar Black
    ...Summary of the Dumps:
    Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
    Debug session time: Thu Oct 28 04:23:38.674 2010 (UTC - 4:00)
    System Uptime: 0 days 0:14:44.000
    BUGCHECK_STR:  0x50
    ииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииии
    Debug session time: Thu Oct 28 02:16:38.977 2010 (UTC - 4:00)
    System Uptime: 0 days 0:36:50.865
  7. Posts : 25
    Sorry for the long response time guys, really hectic weekend, I'm going to try these solutions as soon as I get a chance. Thanks again for the help!
  8. Posts : 25
    So far I've ran the Prime95 test for almost 24 hours and no errors. I'm moving on to the Date Lifeguard tools thing right now. I'll update when it's done.
  9. Posts : 13,354
    Sounds good. Thanks for the progress report!
  10. Posts : 25
    Alright, so I passed the extended test for the hard drive and also tried that furmark thing and it seemed to be fine. The comp has crashed 2 more times though, I'm attaching all of the dump files again. One of them said it was a memory management error this time. I'm going to open up the case and poke around to see if there is anything obvious.
й Designer Media Ltd
