I have "Driver IRQL not less or equal" Problem Please Help...!
  1. Posts : 14
    Windows 7 Ultimate x86
    I have "Driver IRQL not less or equal" Problem Please Help...!(Again!)
    I use Windows 7 Ultimate x86
    I have problem blue screen every day
    Please help me
    upload Dump files...
    My computer info:
    P4 3.0Ghz
    Asus P5Gd1 Pro 1013 beta bios update
    512 mb hd4830 sapphire
    2gb ddr ram
    450 watt psu
    thermaltake cpu fan...
  2. Posts : 28,845
    Win 8 Release candidate 8400
    Please help me
    My computer info:
    P4 3.0Ghz
    2gb ddr ram
    450 watt psu
    Several Problems
    1-ASACPI.SYS
    ASACPI.sys Sun Mar 27 22:30:36 2005
    The 2005 version of this driver is a known BSOD cause.
    Please visit this link: ASUSTeK Computer Inc.-Support- download_item_mkt
    Scroll down to the Utilities category, then scroll down to the "ATK0110 driver for WindowsXP/Vista/Windows 7 32&64-bit " (it's about the 8th item down).
    Download and install it.
    Go to C:\Windows\System32\drivers to check and make sure that the ASACPI.sys file is date stamped from 2009 or 2010 (NOT 2005).
    2-ESET firewall (epwndis.sys)--remove and replace with Microsoft security essentials and win 7 firewall
    http://download.eset.com/special/ESETUninstaller.exe
    http://www.microsoft.com/security_essentials/
    3-netr73.sys Your ralink wifi driver. re-install with most current
    4-old drivers
    ASACPI.sys    8/12/2004 21:52:52        0x91000000    0x411c2d04    0x91001420        0x00001420
    etFilter.sys    6/13/2007 21:09:05        0x90800000    0x4670a341    0x90831200        0x00031200
    etDevice.sys    7/20/2007 13:50:06        0x93438000    0x46a103de    0x934ab300        0x00073300
    etScan.sys    7/23/2007 16:55:22        0x934bc000    0x46a523ca    0x934bda00        0x00001a00
    AsIO.sys    12/17/2007 04:10:20        0x908c0000    0x47663cfc    0x908c1440        0x00001440
    Rtnicxp.sys    5/30/2008 10:12:11        0x917cd000    0x4840194b    0x917dc000        0x0000f000
    netr73.sys    3/12/2009 22:13:15    netr73.sys+7b17c    0x934d3000    0x49b9cf4b    0x93561000        0x0008e000
    How To Find Drivers:
    - search Google for the name of the driver
    - compare the Google results with what's installed on your system to figure out which device/program it belongs to
    - visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
    - if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
    - - The most common drivers are listed on this page: Driver Reference Driver Reference
    - - Driver manufacturer links are on this page: Drivers and Downloads
    Ken J
  3. Posts : 14
    I done everything what you say
    I hope fix problem
    and Ken J thanx for answer if i problem again message here
    thanx again...
  4. Posts : 14
    I did what you say but again blue screen but this time ..000c5
    BCCode: c5
    BCP1: CD815F6E
    BCP2: 00000002
    BCP3: 00000000
    BCP4: 8291971A
    OS Version: 6_1_7600
    Service Pack: 0_0
    Product: 256_1
    end new dump files
    did I nothing wrong ??
    update this:
    ASACPI.sys
    etFilter.sys
    etDevice.sys
    etScan.sys
    AsIO.sys
    Rtnicxp.sys
    netr73.sys
  5. Posts : 8,383
    This new dump blames your ATI display drivers
    Uninstall the ATI drivers then use driver sweeper to remove leftover driver files
    Guru3D - Driver Sweeper
    Then install the latest drivers
    ATI Radeon
    *** WARNING: Unable to verify timestamp for atikmpag.sys
    *** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
    *** WARNING: Unable to verify timestamp for dxgkrnl.sys
    *** ERROR: Module load completed but symbols could not be loaded for dxgkrnl.sys
    Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+12a )
  6. Posts : 14
    mostly restart when I watch video on gom player or bsplayer sometimes play pes 2011
    I use ati latest drivers 10.11 but again I try this!
    yowanvista thanx for answer
  7. Posts : 14
    This time not blue screen and dump files but again restart PC
    Mixed display colors and restart
    my idea : I update my bios Beta 1013 maybe problem is
  8. Posts : 8,383
    This suggest either overheating or a defective GPU, clean out the dust on the GPU
    Revert back to the stable version
  9. Posts : 14
    I did everything what you say but again blue screen
    3 days blue screen dump files
    what my problem I dont know ((
  10. Posts : 28,845
    Your ESET remove and replace with Microsoft security essentials
    And Old, Old drivers that need updating. You obviously upgraded instead of clean installing like MS and ost of us recommend.
    VMNET.SYS    3/16/2007 05:05:31    0x94277000    0x45fa6beb    0x94279a00            0x00002a00
    vmnetbridge.sys    3/16/2007 05:06:36    0x94271000    0x45fa6c2c    0x94276480            0x00005480
    vstor2.sys    3/23/2007 12:02:01    0x9cacb000    0x46040809    0x9cacdd00            0x00002d00
    etFilter.sys    6/13/2007 21:09:05    0x89800000    0x4670a341    0x89831200            0x00031200
    etDevice.sys    7/20/2007 13:50:06    0x94031000    0x46a103de    0x940a4300            0x00073300
    etScan.sys    7/23/2007 16:55:22    0x940b5000    0x46a523ca    0x940b6a00            0x00001a00
    vstor2-ws60.sys    11/30/2007 20:11:19    0x9cace000    0x4750b4b7    0x9cad1100            0x00003100
    AsIO.sys    12/17/2007 04:10:20    0x9051b000    0x47663cfc    0x9051c440            0x00001440
    vmx86.sys    3/3/2008 21:18:07    0x9c895000    0x47ccb15f    0x9c975380            0x000e0380
    VMparport.sys    3/3/2008 21:42:38    0x9c88e000    0x47ccb71e    0x9c895000            0x00007000
    hcmon.sys    3/3/2008 21:44:03    0x9c87c000    0x47ccb773    0x9c887000            0x0000b000
    vmnetuserif.sys    3/3/2008 21:45:54    0x9ca5c000    0x47ccb7e2    0x9ca60800            0x00004800
    VMkbd.sys    3/3/2008 22:11:26    0x90800000    0x47ccbdde    0x90803780            0x00003780
