Problems over problems!
  1. Posts : 2
    Windows 7 Ultimate 64Bit
    first, my pc decided to restart during startup, deactivating automatic restart on errors revealed a BSoD (Stop: 0x0000001E (0xFFFFFFFFC0000005, 0xFFFFF80002E95416, 0x0000000000000000, 0x0000000000000000)).
    I tried booting in safe mode and it worked. However, although I remember having set the option to do minidumps of BSoDs, there was none for this one.
    So I went to the dialog with the settings for that.
    Here is what I got:
    (See attachment)
    Ok, then I tried the system restore and I got a similar useless dialog.
    sfc /scannow tells me that there's a repair operation pending (or was pending) and I'd need to restart (and it still says so after several restarts).
    When I try to use the system restore of the installation disk, it always fails telling me my drive D: (application drive) may be corrupt (chkdsk /R/F returns 0 errors).
    The only thing that has changed were some security updates (kb2552343, kb2547666 and kb255698) and when I try to uninstall them, I just get "Ein Fehler ist aufgetreten. Es konnten nicht alle deinstalliert entfernt werden." (this is the exact message, translated it means "An error occured. Unable to remove every uninstall(?)").
    Does anyone have a tipp for me what I could try next to find at least the source of the problems (preferably without uninstalling all the unnecessary hardware in my pc)?
    Regards
    Tobias
  2. Posts : 6,668
    Windows 7 x64
    It sounds like you are in a repair install situation.
    Repair Install
    It will preserve your data and installed programs but windows will be reset to default settings.
  3. Posts : 2
    Jup that's what I'd have done if noone has another idea.
    Well thanks anyway :)
    Regards
    Tobi
    edit: ok just encountered a "small" problem:
    for a repair install I need to start the setup with windows, however it doesn't work with safe mode and I can't boot up normally since I get the bsod then
    Any other way to do a repair install?
  4. Posts : 6,668
    Windows 7 x64
    ugh that stinks you can still do a fresh install and have it save the data from the previous install.
    In case of future problems I suggest you make a proper repair disc for future recovery.
    They can boot and repair for you.
