Monitors and sound cut out, fans and HDDs kept running, had to hard re
  1. Posts : 58
    Win 7 Home Premium x64
    Both monitors and my external Sound Blaster Omni cut out, power light stayed on, hdd lights kept flashing like normal, fans stayed on. I had to press the reset button to get my PC back and it went through the typical "This computer did not shut off properly" screen before logging into Windows.
    When I clicked "Grab All" on the tool, it said it could not retrieve the dump file. I have no idea why. This is all it would collect.
  2. Posts : 7,053
    Windows 10 Pro
    That message may be because there have been no dumps created.
    Please make sure your pc is configured for small dump files How to configure minidump | Windows 7 tutorial
  3. Posts : 58
    Everything is set up to create kernel dumps. Perhaps it didn't BSOD on me, but it simply turned off the monitors and sound. In that case it wouldn't create a dump would it? Maybe it just went into sleep mode by itself. Everything inside the computer was still running which is what is confusing.
  4. Posts : 7,053
    Windows 10 Pro
    I think it is more an issue with your graphics instead.
    Create a thread at https://www.sevenforums.com/performance-maintenance/ OR https://www.sevenforums.com/general-discussion/
    If the thread isn't at the right place it'll be moved by a moderator or admin within time.
