Problem With Desktop Icon.HELP!!
The picture tells u.there is always a blank at the bottom left hand corner of the shortcut.please help.
https://www.sevenforums.com/attachmen...1&d=1259119122
Did you use a tweak to change or remove the shortcut arrow?
Hi and welcome
that is the shortcut arrow. look here How to remove or modify the Shortcut overlay in Windows 7 and Vista for how to change it
Hope this helps
Ken J++
I'll give it a try.thks 4 the quick reply!Hi and welcome
Hope this helps
Ken J++
This is my first post. Not sure if it should be here or not. If not, please inform where it should be........
I also have an icon problem.... I have 5 icons of data files on my desktop and everytime I work with them and save them, they change place. I try to find an option to lock them in place but there doesn't seem to be any.
Does anyone have an answer????
JohnB
