#61
The error indicated fileinfo.sys
I would suggest to try running Startup Repair from the installation DVD. Startup Repair will check the filesystem on the disk (FILEINFO.SYS errors). If it doesn't complete successfully, then you'll have to run chkdsk /r from the Command Prompt.
Bugcheck
~TuanCode:Microsoft (R) Windows Debugger Version 6.12.0002.633 X86 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\TUANTR~1\AppData\Local\Temp\Rar$DI02.872\062610-18642-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*e:\symbols*http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7600.16539.x86fre.win7_gdr.100226-1909 Machine Name: Kernel base = 0x81811000 PsLoadedModuleList = 0x81950570 Debug session time: Sat Jun 26 07:21:15.294 2010 (UTC + 7:00) System Uptime: 0 days 0:44:14.934 Loading Kernel Symbols ............................................................... ................................................................ ................. Loading User Symbols Loading unloaded module list ...... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 1000008E, {c0000005, 86bab885, a6807810, 0} Probably caused by : fileinfo.sys ( fileinfo!FIStreamGet+36 ) Followup: MachineOwner ---------
