#71
Had a crash..
This time, it's still point to memory corruption my friend
Are you sure you have run memtest86 for at least 7 passes, one stick on different slot??Code:Microsoft (R) Windows Debugger Version 6.12.0002.633 X86 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\TUANTR~1\AppData\Local\Temp\Rar$DI00.608\062710-24554-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*e:\symbols*http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7600.16385.x86fre.win7_rtm.090713-1255 Machine Name: Kernel base = 0x8180c000 PsLoadedModuleList = 0x8194b570 Debug session time: Sun Jun 27 20:50:57.134 2010 (UTC + 7:00) System Uptime: 0 days 1:17:24.775 Loading Kernel Symbols ............................................................... ................................................................ .................... Loading User Symbols Loading unloaded module list ....... 1: kd> !analyze ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 1A, {5003, 87400000, 3a5d, 65676173} Probably caused by : memory_corruption ( nt!MiAllocateWsle+6f ) Followup: MachineOwner ---------
~Tuan
Please remove Kaspersky: http://support.kaspersky.com/downloa...vremover10.zip
Replace with MSE: http://www.microsoft.com/security_essentials
Code:Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\Jonathan\AppData\Local\Temp\Temp1_062710-24554-01.zip\062710-24554-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7600.16385.x86fre.win7_rtm.090713-1255 Machine Name: Kernel base = 0x8180c000 PsLoadedModuleList = 0x8194b570 Debug session time: Sun Jun 27 09:50:57.134 2010 (UTC - 4:00) System Uptime: 0 days 1:17:24.775 Loading Kernel Symbols ............................................................... ................................................................ .................... Loading User Symbols Loading unloaded module list ....... 1: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* MEMORY_MANAGEMENT (1a) # Any other values for parameter 1 must be individually examined. Arguments: Arg1: 00005003, The subtype of the bugcheck. Arg2: 87400000 Arg3: 00003a5d Arg4: 65676173 Debugging Details: ------------------ BUGCHECK_STR: 0x1a_5003 CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT PROCESS_NAME: firefox.exe CURRENT_IRQL: 0 LAST_CONTROL_TRANSFER: from 8188212a to 818dd574 STACK_TEXT: a56556ac 8188212a 0000001a 00005003 87400000 nt!KeBugCheckEx+0x1e a56556e0 818a4418 c0281280 82cf7950 00000000 nt!MiAllocateWsle+0x6f a565578c 81876b4e c0281280 a56557f0 00000001 nt!MiMakeSystemCacheRangeValid+0xb7 a5655834 8189fe01 a04a0000 00001000 00000001 nt!MmCheckCachedPageStates+0x73f a565586c 818a4922 00000006 00000001 a04a0000 nt!CcMapAndRead+0xbf a56558e4 8182d89b 8500bea8 a5655928 00001c00 nt!CcPinFileData+0x2dd a5655964 819d6662 84f07688 00000000 00c11b01 nt!CcZeroDataInCache+0x5a a56559a8 86c92bfd 84f07688 a56559f8 a56559e8 nt!CcZeroData+0x199 a5655a30 86c3841c 850e60e8 a6ee30f8 84f07688 Ntfs!NtfsZeroData+0x355 a5655b48 86c3985f 850e60e8 834c4a38 23a330bc Ntfs!NtfsCommonWrite+0x2233 a5655bc0 8183af44 84043020 834c4a38 834c4a38 Ntfs!NtfsFsdWrite+0x2e1 a5655bd8 86bae20c 840849e0 834c4a38 00000000 nt!IofCallDriver+0x63 a5655bfc 86bae3cb a5655c1c 840849e0 00000000 fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x2aa a5655c34 8183af44 840849e0 834c4a38 834c4a38 fltmgr!FltpDispatch+0xc5 a5655c4c 81a10287 84f07688 834c4a38 834c4c10 nt!IofCallDriver+0x63 a5655c6c 81a25f09 840849e0 84f07688 00000001 nt!IopSynchronousServiceTail+0x1f8 a5655d08 8184179a 840849e0 00000000 00000000 nt!NtWriteFile+0x6e8 a5655d08 770464f4 840849e0 00000000 00000000 nt!KiFastCallEntry+0x12a WARNING: Frame IP not in any known module. Following frames may be wrong. 0017f8a4 00000000 00000000 00000000 00000000 0x770464f4 STACK_COMMAND: kb FOLLOWUP_IP: nt!MiAllocateWsle+6f 8188212a cc int 3 SYMBOL_STACK_INDEX: 1 SYMBOL_NAME: nt!MiAllocateWsle+6f FOLLOWUP_NAME: MachineOwner MODULE_NAME: nt DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bbffc IMAGE_NAME: memory_corruption FAILURE_BUCKET_ID: 0x1a_5003_nt!MiAllocateWsle+6f BUCKET_ID: 0x1a_5003_nt!MiAllocateWsle+6f Followup: MachineOwner --------- 1: kd> lmntsm start end module name 86a3b000 86a83000 ACPI ACPI.sys Mon Jul 13 19:11:11 2009 (4A5BBF0F) 8b53b000 8b595000 afd afd.sys Mon Jul 13 19:12:34 2009 (4A5BBF62) 8b7a5000 8b7b7000 AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954) 86b9f000 86ba8000 amdxata amdxata.sys Tue May 19 13:57:35 2009 (4A12F30F) 86b73000 86b7c000 atapi atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13) 86b7c000 86b9f000 ataport ataport.SYS Mon Jul 13 19:11:18 2009 (4A5BBF16) 8be37000 8bf47000 athr athr.sys Tue Jun 09 14:04:52 2009 (4A2EA444) 86ae2000 86aed000 BATTC BATTC.SYS Mon Jul 13 19:19:15 2009 (4A5BC0F3) 87318000 8731f000 Beep Beep.SYS Mon Jul 13 19:45:00 2009 (4A5BC6FC) 8b713000 8b721000 blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8) 868c7000 868cf000 BOOTVID BOOTVID.dll Mon Jul 13 21:04:34 2009 (4A5BD9A2) 8d5b1000 8d5ca000 bowser bowser.sys Mon Jul 13 19:14:21 2009 (4A5BBFCD) 81380000 8139e000 cdd cdd.dll unavailable (00000000) 86911000 869bc000 CI CI.dll Mon Jul 13 21:09:28 2009 (4A5BDAC8) 87269000 8728e000 CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18) 868cf000 86911000 CLFS CLFS.SYS Mon Jul 13 19:11:10 2009 (4A5BBF0E) 8b754000 8b757700 CmBatt CmBatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6) 86d95000 86df2000 cng cng.sys Mon Jul 13 19:32:55 2009 (4A5BC427) 86ada000 86ae2000 compbatt compbatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6) 8b798000 8b7a5000 CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716) 873f2000 873ff000 crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E) 8b697000 8b6fb000 csc csc.sys Mon Jul 13 19:15:08 2009 (4A5BBFFC) 8b6fb000 8b713000 dfsc dfsc.sys Mon Jul 13 19:14:16 2009 (4A5BBFC8) 8b68b000 8b697000 discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214) 87258000 87269000 disk disk.sys Mon Jul 13 19:11:28 2009 (4A5BBF20) 8bfce000 8bfd8000 DKbFltr DKbFltr.sys Wed Mar 25 23:10:12 2009 (49CAF214) 8d7dc000 8d7e4f00 DKRtWrt DKRtWrt.sys Wed Oct 21 04:01:19 2009 (4ADEBFCF) 86c00000 86c19000 drmk drmk.sys Mon Jul 13 20:36:05 2009 (4A5BD2F5) 87299000 872a2000 dump_atapi dump_atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13) 8728e000 87299000 dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14) 872a2000 872b3000 dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F) 872b3000 872bd000 Dxapi Dxapi.sys Mon Jul 13 19:25:25 2009 (4A5BC265) 8bd03000 8bdba000 dxgkrnl dxgkrnl.sys Mon Jul 13 19:26:15 2009 (4A5BC297) 8bdba000 8bdf3000 dxgmms1 dxgmms1.sys Mon Jul 13 19:25:25 2009 (4A5BC265) 86bdc000 86bed000 fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F) 86ba8000 86bdc000 fltmgr fltmgr.sys Mon Jul 13 19:11:13 2009 (4A5BBF11) 86e00000 86e09000 Fs_Rec Fs_Rec.sys unavailable (00000000) 87226000 87258000 fvevol fvevol.sys Mon Jul 13 19:13:01 2009 (4A5BBF7D) 87153000 87184000 fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43) 81c0c000 81c43000 hal halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07) 8bdf3000 8be12000 HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F) 86fac000 86ffc000 HdAudio HdAudio.sys Mon Jul 13 19:51:46 2009 (4A5BC892) 8d52c000 8d5b1000 HTTP HTTP.sys Mon Jul 13 19:12:53 2009 (4A5BBF75) 8721e000 87226000 hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05) 8bfb6000 8bfce000 i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B) 8b806000 8bd03000 igdkmd32 igdkmd32.sys Tue Jun 16 14:28:17 2009 (4A37E441) 86b48000 86b4f000 intelide intelide.sys Mon Jul 13 19:11:19 2009 (4A5BBF17) 8b742000 8b754000 intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07) 8bfd8000 8bfe5000 kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13) 81673000 8167b000 kdcom kdcom.dll Mon Jul 13 21:08:58 2009 (4A5BDAAA) 8b01b000 8b53b000 kl1 kl1.sys Tue Sep 01 07:29:07 2009 (4A9D0583) 87211000 8721e000 klbg klbg.sys Wed Oct 14 13:18:07 2009 (4AD607CF) 872c0000 87311000 klif klif.sys Wed Nov 11 08:32:39 2009 (4AFABCF7) 8b5fe000 8b605000 klim6 klim6.sys Tue Nov 03 08:33:26 2009 (4AF03126) 8bfe7000 8bff0000 klmouflt klmouflt.sys Fri Oct 02 11:38:31 2009 (4AC61E77) 86f23000 86f57000 ks ks.sys Mon Jul 13 19:45:13 2009 (4A5BC709) 86d82000 86d95000 ksecdd ksecdd.sys Mon Jul 13 19:11:56 2009 (4A5BBF3C) 86efe000 86f23000 ksecpkg ksecpkg.sys Mon Jul 13 19:34:00 2009 (4A5BC468) 8d4b3000 8d4c3000 lltdio lltdio.sys Mon Jul 13 19:53:18 2009 (4A5BC8EE) 8d47e000 8d499000 luafv luafv.sys Mon Jul 13 19:15:44 2009 (4A5BC020) 8683e000 868b6000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:06:41 2009 (4A5BDA21) 8d473000 8d47e000 monitor monitor.sys Mon Jul 13 19:25:58 2009 (4A5BC286) 8bff0000 8bffd000 mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13) 86b5d000 86b73000 mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F) 8d5ca000 8d5dc000 mpsdrv mpsdrv.sys Mon Jul 13 19:52:52 2009 (4A5BC8D4) 8d5dc000 8d5ff000 mrxsmb mrxsmb.sys Mon Jul 13 19:14:24 2009 (4A5BBFD0) 8d5ff000 8d63a000 mrxsmb10 mrxsmb10.sys Mon Jul 13 19:14:34 2009 (4A5BBFDA) 8d63a000 8d655000 mrxsmb20 mrxsmb20.sys Mon Jul 13 19:14:29 2009 (4A5BBFD5) 87371000 8737c000 Msfs Msfs.SYS Mon Jul 13 19:11:26 2009 (4A5BBF1E) 86a8c000 86a94000 msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D) 86d57000 86d82000 msrpc msrpc.sys unavailable (00000000) 8b681000 8b68b000 mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD) 87201000 87211000 mup mup.sys Mon Jul 13 19:14:14 2009 (4A5BBFC6) 86e09000 86ec0000 ndis ndis.sys Mon Jul 13 19:12:24 2009 (4A5BBF58) 8b7cf000 8b7da000 ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930) 8d509000 8d519000 ndisuio ndisuio.sys Mon Jul 13 19:53:51 2009 (4A5BC90F) 8b7da000 8b7fc000 ndiswan ndiswan.sys Mon Jul 13 19:54:34 2009 (4A5BC93A) 86f9b000 86fac000 NDProxy NDProxy.SYS Mon Jul 13 19:54:27 2009 (4A5BC933) 8b605000 8b613000 netbios netbios.sys Mon Jul 13 19:53:54 2009 (4A5BC912) 8b595000 8b5c7000 netbt netbt.sys Mon Jul 13 19:12:18 2009 (4A5BBF52) 86ec0000 86efe000 NETIO NETIO.SYS Mon Jul 13 19:12:35 2009 (4A5BBF63) 8737c000 8738a000 Npfs Npfs.SYS Mon Jul 13 19:11:31 2009 (4A5BBF23) 8b677000 8b681000 nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48) 8180c000 81c0c000 nt ntkrnlmp.exe Mon Jul 13 19:15:08 2009 (4A5BBFFC) 86c28000 86d57000 Ntfs Ntfs.sys Mon Jul 13 19:12:05 2009 (4A5BBF45) 87311000 87318000 Null Null.SYS unavailable (00000000) 8d4c3000 8d509000 nwifi nwifi.sys Mon Jul 13 19:51:59 2009 (4A5BC89F) 8b5ce000 8b5ed000 pacer pacer.sys Mon Jul 13 19:53:58 2009 (4A5BC916) 86ac9000 86ada000 partmgr partmgr.sys Mon Jul 13 19:11:35 2009 (4A5BBF27) 86a94000 86abe000 pci pci.sys Mon Jul 13 19:11:16 2009 (4A5BBF14) 86b4f000 86b5d000 PCIIDEX PCIIDEX.SYS Mon Jul 13 19:11:15 2009 (4A5BBF13) 86df2000 86e00000 pcw pcw.sys Mon Jul 13 19:11:10 2009 (4A5BBF0E) 8d66d000 8d704000 peauth peauth.sys Mon Jul 13 20:35:44 2009 (4A5BD2E0) 86800000 8682f000 portcls portcls.sys Mon Jul 13 19:51:00 2009 (4A5BC864) 868b6000 868c7000 PSHED PSHED.dll Mon Jul 13 21:09:36 2009 (4A5BDAD0) 8b7b7000 8b7cf000 rasl2tp rasl2tp.sys Mon Jul 13 19:54:33 2009 (4A5BC939) 8b000000 8b018000 raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D) 873ac000 873c3000 raspptp raspptp.sys Mon Jul 13 19:54:47 2009 (4A5BC947) 873c3000 873da000 rassstp rassstp.sys Mon Jul 13 19:54:57 2009 (4A5BC951) 8b636000 8b677000 rdbss rdbss.sys Mon Jul 13 19:14:26 2009 (4A5BBFD2) 873da000 873e4000 rdpbus rdpbus.sys Mon Jul 13 20:02:40 2009 (4A5BCB20) 87359000 87361000 RDPCDD RDPCDD.sys Mon Jul 13 20:01:40 2009 (4A5BCAE4) 87361000 87369000 rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3) 87369000 87371000 rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5) 871d4000 87201000 rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A) 8d519000 8d52c000 rspndr rspndr.sys Mon Jul 13 19:53:20 2009 (4A5BC8F0) 8be12000 8be37000 Rt86win7 Rt86win7.sys Thu Feb 26 04:04:22 2009 (49A65B16) 8d704000 8d70e000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528) 871cc000 871d4000 spldr spldr.sys Mon May 11 12:13:47 2009 (4A084EBB) b2823000 b288d000 spsys spsys.sys Mon May 11 12:37:10 2009 (4A085436) 8d78b000 8d7dc000 srv srv.sys Mon Jul 13 19:15:10 2009 (4A5BBFFE) 8d73c000 8d78b000 srv2 srv2.sys Mon Jul 13 19:14:52 2009 (4A5BBFEC) 8d70e000 8d72f000 srvnet srvnet.sys Mon Jul 13 19:14:45 2009 (4A5BBFE5) 8bffd000 8bffe380 swenum swenum.sys Mon Jul 13 19:45:08 2009 (4A5BC704) 8b758000 8b78e400 SynTP SynTP.sys Thu Sep 03 20:32:25 2009 (4AA06019) 8700a000 87153000 tcpip tcpip.sys Mon Jul 13 19:13:18 2009 (4A5BBF8E) 8d72f000 8d73c000 tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926) 873a1000 873ac000 TDI TDI.SYS Mon Jul 13 19:12:12 2009 (4A5BBF4C) 8738a000 873a1000 tdx tdx.sys Mon Jul 13 19:12:10 2009 (4A5BBF4A) 8b626000 8b636000 termdd termdd.sys Mon Jul 13 20:01:35 2009 (4A5BCADF) 81350000 81359000 TSDDD TSDDD.dll unavailable (00000000) 8b721000 8b742000 tunnel tunnel.sys Mon Jul 13 19:54:03 2009 (4A5BC91B) 873e4000 873f2000 umbus umbus.sys Mon Jul 13 19:51:38 2009 (4A5BC88A) 8d438000 8d44f000 usbccgp usbccgp.sys Mon Jul 13 19:51:31 2009 (4A5BC883) 8bfe5000 8bfe6700 USBD USBD.SYS Mon Jul 13 19:51:05 2009 (4A5BC869) 8bfa7000 8bfb6000 usbehci usbehci.sys Mon Jul 13 19:51:14 2009 (4A5BC872) 86f57000 86f9b000 usbhub usbhub.sys Mon Jul 13 19:52:06 2009 (4A5BC8A6) 8bf5c000 8bfa7000 USBPORT USBPORT.SYS Mon Jul 13 19:51:13 2009 (4A5BC871) 8bf51000 8bf5c000 usbuhci usbuhci.sys Mon Jul 13 19:51:10 2009 (4A5BC86E) 8d44f000 8d472b00 usbvideo usbvideo.sys Mon Jul 13 19:51:51 2009 (4A5BC897) 86abe000 86ac9000 vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B) 8731f000 8732b000 vga vga.sys Mon Jul 13 19:25:50 2009 (4A5BC27E) 8732b000 8734c000 VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D) 87184000 8718d000 vmstorfl vmstorfl.sys unavailable (00000000) 86aed000 86afd000 volmgr volmgr.sys Mon Jul 13 19:11:25 2009 (4A5BBF1D) 86afd000 86b48000 volmgrx volmgrx.sys unavailable (00000000) 8718d000 871cc000 volsnap volsnap.sys Mon Jul 13 19:11:34 2009 (4A5BBF26) 8bf47000 8bf51000 vwifibus vwifibus.sys Mon Jul 13 19:52:02 2009 (4A5BC8A2) 8b5ed000 8b5fe000 vwififlt vwififlt.sys Mon Jul 13 19:52:03 2009 (4A5BC8A3) 8b613000 8b626000 wanarp wanarp.sys Mon Jul 13 19:55:02 2009 (4A5BC956) 8734c000 87359000 watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A) 869bc000 86a2d000 Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28) 86a2d000 86a3b000 WDFLDR WDFLDR.SYS Mon Jul 13 19:11:25 2009 (4A5BBF1D) 8b5c7000 8b5ce000 wfplwf wfplwf.sys Mon Jul 13 19:53:51 2009 (4A5BC90F) 810f0000 8133a000 win32k win32k.sys Mon Jul 13 19:26:26 2009 (4A5BC2A2) 8b78f000 8b798000 wmiacpi wmiacpi.sys Mon Jul 13 19:19:16 2009 (4A5BC0F4) 86a83000 86a8c000 WMILIB WMILIB.SYS Mon Jul 13 19:11:22 2009 (4A5BBF1A) 8d499000 8d4b3000 WudfPf WudfPf.sys Mon Jul 13 19:50:13 2009 (4A5BC835) Unloaded modules: 8d7e7000 8d7e9000 MSPCLOCK.sys Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 00002000 8d7e5000 8d7e7000 MSPQM.sys Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 00002000 8d655000 8d66d000 parport.sys Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 00018000 8728e000 8729b000 crashdmp.sys Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 0000D000 8729b000 872a6000 dump_ataport Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 0000B000 872a6000 872af000 dump_atapi.s Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 00009000 872af000 872c0000 dump_dumpfve Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 00011000
I am not that happy about MSE, sometimes it just turns off the virus protection, and tells me to turn it on again. And when I do that, it is activated for about 10 seconds and turns of again, and I have to reboot, to get it to work.
I suggest posting in the Security section of this forum to get that issue sorted out: System Security - Windows 7 Forums
But why do Eset NOD32 or Kaspersky cause a BSOD? I am installing MSE right now, I would just like to know why it is better..
MSE- Microsoft Security Essentials. It is by Microsoft, who know Windows well enough to create an AV that works well with it.
ESET is good, at least the updated version. It is not free, which is why I recommend MSE.
Kaspersky is well known for causing BSODs, and it is not free as well.
Well okay, I thought NOD32 was great and light on my system, so I was willing to buy it. But I didn't knew that Kaspersky caused problems..
yeah, Kaspersky run well in many machines but not well in many as well. Others such as Norton or AVG are known for causing problem too my friend (I was victim of free AVG). We recommended you to uninstall those heavy AV just for testing purpose. It might not be the cause on yours (we don't know yet)
Wish u all the best my friend, if you bought it already, it's not bad at all, always can switch back to it if it's not the cause
Cheer
