#111
In that case, replace/increase your RAM ....
It still have its Warranty, so I will just send it to be repaired and tell 'em whats wrong..
Memory corruption can be caused by many things other than bad RAM such as drivers, incompatible software, other hardware problems, etc. sptd.sys is a prime example of a driver causing memory corruption.
That is not a bad idea while it is still under warranty. I recommend that you follow Tew's advice and add RAM. That alone won't eliminate memory corruption; but it will speed up your system. A total of 2 megs would be a good start for your system.
well, it is not possible for ME to insert new ram, without voiding the warrenty..
I saw under a BSOD that is said something with 'mrspc.sys'
Just upload the new dmps. If I don't see SPTD.sys in the dump (a sure sign of Daemon Tools), then we can work on another solution.
Looks like a repair install is in order.
Also do a system files check:Are you using any registry cleaning programs?JK said:
Download a copy of Memtest86 and burn the ISO to a CD using Iso Recorder or another ISO burning program. Boot from the CD, and leave it running for at least 5 or 6 passes.
Try a hard drive test: HD DiagnosticCode:Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\Jonathan\_jcgriff2_\dbug\__Kernel__\071010-20670-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7600.16539.x86fre.win7_gdr.100226-1909 Machine Name: Kernel base = 0x8183e000 PsLoadedModuleList = 0x8197d570 Debug session time: Sat Jul 10 09:18:43.818 2010 (UTC - 4:00) System Uptime: 0 days 3:46:39.458 Loading Kernel Symbols ............................................................... ................................................................ ............... Loading User Symbols Loading unloaded module list ........ 1: kd> !analyze -v;lmtsmn;.bugcheck;.logclose;q ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* REGISTRY_ERROR (51) Something has gone badly wrong with the registry. If a kernel debugger is available, get a stack trace. It can also indicate that the registry got an I/O error while trying to read one of its files, so it can be caused by hardware problems or filesystem corruption. It may occur due to a failure in a refresh operation, which is used only in by the security system, and then only when resource limits are encountered. Arguments: Arg1: 00000001, (reserved) Arg2: a1265008, (reserved) Arg3: 00192000, depends on where Windows bugchecked, may be pointer to hive Arg4: 00000374, depends on where Windows bugchecked, may be return code of HvCheckHive if the hive is corrupt. Debugging Details: ------------------ CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT BUGCHECK_STR: 0x51 PROCESS_NAME: explorer.exe CURRENT_IRQL: 0 LAST_CONTROL_TRANSFER: from 81a73933 to 8190f574 STACK_TEXT: a2119b04 81a73933 00000051 00000001 a1265008 nt!KeBugCheckEx+0x1e a2119b4c 81a6845f 00192000 01e92000 00000004 nt!HvpSetRangeProtection+0x40 a2119b84 81a69f3c a1265008 000021b4 02021810 nt!HvMarkDirty+0x43b a2119bac 81a65823 000021b8 00000000 b449aa3c nt!HvMarkCellDirty+0x235 a2119c58 81aa0119 8bfc7550 a2119cd0 00000001 nt!CmSetValueKey+0x6e9 a2119d14 8187379a 00000b64 043ce868 00000000 nt!NtSetValueKey+0x32b a2119d14 77b964f4 00000b64 043ce868 00000000 nt!KiFastCallEntry+0x12a WARNING: Frame IP not in any known module. Following frames may be wrong. 043ce870 00000000 00000000 00000000 00000000 0x77b964f4 STACK_COMMAND: kb FOLLOWUP_IP: nt!HvpSetRangeProtection+40 81a73933 cc int 3 SYMBOL_STACK_INDEX: 1 SYMBOL_NAME: nt!HvpSetRangeProtection+40 FOLLOWUP_NAME: MachineOwner MODULE_NAME: nt IMAGE_NAME: ntkrnlmp.exe DEBUG_FLR_IMAGE_TIMESTAMP: 4b88cac3 FAILURE_BUCKET_ID: 0x51_nt!HvpSetRangeProtection+40 BUCKET_ID: 0x51_nt!HvpSetRangeProtection+40 Followup: MachineOwner --------- start end module name 86a09000 86a51000 ACPI ACPI.sys Mon Jul 13 19:11:11 2009 (4A5BBF0F) 87386000 873e0000 afd afd.sys Mon Jul 13 19:12:34 2009 (4A5BBF62) 8b137000 8b149000 AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954) 86b6d000 86b76000 amdxata amdxata.sys Tue May 19 13:57:35 2009 (4A12F30F) 86b41000 86b4a000 atapi atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13) 86b4a000 86b6d000 ataport ataport.SYS Mon Jul 13 19:11:18 2009 (4A5BBF16) 8ba55000 8bb65000 athr athr.sys Tue Jun 09 14:04:52 2009 (4A2EA444) 86ab0000 86abb000 BATTC BATTC.SYS Mon Jul 13 19:19:15 2009 (4A5BC0F3) 872f2000 872f9000 Beep Beep.SYS Mon Jul 13 19:45:00 2009 (4A5BC6FC) 8b0ae000 8b0bc000 blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8) 86895000 8689d000 BOOTVID BOOTVID.dll Mon Jul 13 21:04:34 2009 (4A5BD9A2) a1d06000 a1d1f000 bowser bowser.sys Mon Jul 13 19:14:21 2009 (4A5BBFCD) 8d6d0000 8d6ee000 cdd cdd.dll Mon Jul 13 21:04:18 2009 (4A5BD992) 868df000 8698a000 CI CI.dll Mon Jul 13 21:09:28 2009 (4A5BDAC8) 87252000 87277000 CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18) 8689d000 868df000 CLFS CLFS.SYS Mon Jul 13 19:11:10 2009 (4A5BBF0E) 8b0ef000 8b0f2700 CmBatt CmBatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6) 86d8e000 86deb000 cng cng.sys Mon Jul 13 19:32:55 2009 (4A5BC427) 86aa8000 86ab0000 compbatt compbatt.sys Mon Jul 13 19:19:18 2009 (4A5BC0F6) 8b12a000 8b137000 CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716) 8b30d000 8b31a000 crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E) 8b032000 8b096000 csc csc.sys Mon Jul 13 19:15:08 2009 (4A5BBFFC) 8b096000 8b0ae000 dfsc dfsc.sys Mon Jul 13 19:14:16 2009 (4A5BBFC8) 86fd4000 86fe0000 discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214) 87241000 87252000 disk disk.sys Mon Jul 13 19:11:28 2009 (4A5BBF20) 8bbec000 8bbf6000 DKbFltr DKbFltr.sys Wed Mar 25 23:10:12 2009 (49CAF214) a1f30000 a1f38f00 DKRtWrt DKRtWrt.sys Wed Oct 21 04:01:19 2009 (4ADEBFCF) 8b2f4000 8b30d000 drmk drmk.sys Mon Jul 13 20:36:05 2009 (4A5BD2F5) 8b325000 8b32e000 dump_atapi dump_atapi.sys Mon Jul 13 19:11:15 2009 (4A5BBF13) 8b31a000 8b325000 dump_dumpata dump_dumpata.sys Mon Jul 13 19:11:16 2009 (4A5BBF14) 8b32e000 8b33f000 dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F) 8b33f000 8b349000 Dxapi Dxapi.sys Mon Jul 13 19:25:25 2009 (4A5BC265) 8b921000 8b9d8000 dxgkrnl dxgkrnl.sys Thu Oct 01 20:48:33 2009 (4AC54DE1) 8b9d8000 8ba11000 dxgmms1 dxgmms1.sys Mon Jul 13 19:25:25 2009 (4A5BC265) 86baa000 86bbb000 fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F) 86b76000 86baa000 fltmgr fltmgr.sys Mon Jul 13 19:11:13 2009 (4A5BBF11) 86df9000 86e02000 Fs_Rec Fs_Rec.sys unavailable (00000000) 8720f000 87241000 fvevol fvevol.sys Fri Sep 25 22:24:21 2009 (4ABD7B55) 87149000 8717a000 fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43) 81807000 8183e000 hal halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07) 8ba11000 8ba30000 HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F) 8b275000 8b2c5000 HdAudio HdAudio.sys Mon Jul 13 19:51:46 2009 (4A5BC892) a1c81000 a1d06000 HTTP HTTP.sys Mon Jul 13 19:12:53 2009 (4A5BBF75) 87207000 8720f000 hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05) 8bbd4000 8bbec000 i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B) 8b424000 8b921000 igdkmd32 igdkmd32.sys Tue Jun 16 14:28:17 2009 (4A37E441) 86b16000 86b1d000 intelide intelide.sys Mon Jul 13 19:11:19 2009 (4A5BBF17) 8b0dd000 8b0ef000 intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07) 8b400000 8b40d000 kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13) 816c4000 816cc000 kdcom kdcom.dll Mon Jul 13 21:08:58 2009 (4A5BDAAA) 8b1de000 8b212000 ks ks.sys Mon Jul 13 19:45:13 2009 (4A5BC709) 86d7b000 86d8e000 ksecdd ksecdd.sys Mon Jul 13 19:11:56 2009 (4A5BBF3C) 86ef7000 86f1c000 ksecpkg ksecpkg.sys Thu Dec 10 23:04:22 2009 (4B21C4C6) 8b3c4000 8b3d4000 lltdio lltdio.sys Mon Jul 13 19:53:18 2009 (4A5BC8EE) 8b38f000 8b3aa000 luafv luafv.sys Mon Jul 13 19:15:44 2009 (4A5BC020) 8680c000 86884000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:06:41 2009 (4A5BDA21) 8b349000 8b354000 monitor monitor.sys Mon Jul 13 19:25:58 2009 (4A5BC286) 8b40f000 8b41c000 mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13) 86b2b000 86b41000 mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F) 872c8000 872eb000 MpFilter MpFilter.sys Sat Mar 20 00:03:26 2010 (4BA4490E) a1f27000 a1f2fe00 MpNWMon MpNWMon.sys Sat Mar 20 00:03:24 2010 (4BA4490C) a1d1f000 a1d31000 mpsdrv mpsdrv.sys Mon Jul 13 19:52:52 2009 (4A5BC8D4) a1d31000 a1d54000 mrxsmb mrxsmb.sys Sat Feb 27 02:32:02 2010 (4B88CA72) a1d54000 a1d8f000 mrxsmb10 mrxsmb10.sys Sat Feb 27 02:32:21 2010 (4B88CA85) a1d8f000 a1daa000 mrxsmb20 mrxsmb20.sys Sat Feb 27 02:32:11 2010 (4B88CA7B) 8734b000 87356000 Msfs Msfs.SYS Mon Jul 13 19:11:26 2009 (4A5BBF1E) 86a5a000 86a62000 msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D) 86d50000 86d7b000 msrpc msrpc.sys unavailable (00000000) 86fca000 86fd4000 mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD) 871f7000 87207000 mup mup.sys Mon Jul 13 19:14:14 2009 (4A5BBFC6) 86e02000 86eb9000 ndis ndis.sys Mon Jul 13 19:12:24 2009 (4A5BBF58) 8b161000 8b16c000 ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930) a1c5e000 a1c6e000 ndisuio ndisuio.sys Mon Jul 13 19:53:51 2009 (4A5BC90F) 8b16c000 8b18e000 ndiswan ndiswan.sys Mon Jul 13 19:54:34 2009 (4A5BC93A) 8b264000 8b275000 NDProxy NDProxy.SYS Mon Jul 13 19:54:27 2009 (4A5BC933) 86f4e000 86f5c000 netbios netbios.sys Mon Jul 13 19:53:54 2009 (4A5BC912) 86f1c000 86f4e000 netbt netbt.sys Mon Jul 13 19:12:18 2009 (4A5BBF52) 86eb9000 86ef7000 NETIO NETIO.SYS Mon Jul 13 19:12:35 2009 (4A5BBF63) 87356000 87364000 Npfs Npfs.SYS Mon Jul 13 19:11:31 2009 (4A5BBF23) 86fc0000 86fca000 nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48) 8183e000 81c3e000 nt ntkrnlmp.exe Sat Feb 27 02:33:23 2010 (4B88CAC3) 86c21000 86d50000 Ntfs Ntfs.sys Mon Jul 13 19:12:05 2009 (4A5BBF45) 872eb000 872f2000 Null Null.SYS unavailable (00000000) a1c18000 a1c5e000 nwifi nwifi.sys Mon Jul 13 19:51:59 2009 (4A5BC89F) 872a9000 872c8000 pacer pacer.sys Mon Jul 13 19:53:58 2009 (4A5BC916) 86a97000 86aa8000 partmgr partmgr.sys Mon Jul 13 19:11:35 2009 (4A5BBF27) 86a6d000 86a97000 pci pci.sys Mon Jul 13 19:11:16 2009 (4A5BBF14) 86b1d000 86b2b000 PCIIDEX PCIIDEX.SYS Mon Jul 13 19:11:15 2009 (4A5BBF13) 86deb000 86df9000 pcw pcw.sys Mon Jul 13 19:11:10 2009 (4A5BBF0E) a1dc2000 a1e59000 peauth peauth.sys Mon Jul 13 20:35:44 2009 (4A5BD2E0) 8b2c5000 8b2f4000 portcls portcls.sys Mon Jul 13 19:51:00 2009 (4A5BC864) 86884000 86895000 PSHED PSHED.dll Mon Jul 13 21:09:36 2009 (4A5BDAD0) 8b149000 8b161000 rasl2tp rasl2tp.sys Mon Jul 13 19:54:33 2009 (4A5BC939) 8b18e000 8b1a6000 raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D) 8b1a6000 8b1bd000 raspptp raspptp.sys Mon Jul 13 19:54:47 2009 (4A5BC947) 8b1bd000 8b1d4000 rassstp rassstp.sys Mon Jul 13 19:54:57 2009 (4A5BC951) 86f7f000 86fc0000 rdbss rdbss.sys Mon Jul 13 19:14:26 2009 (4A5BBFD2) 8b1d4000 8b1de000 rdpbus rdpbus.sys Mon Jul 13 20:02:40 2009 (4A5BCB20) 87333000 8733b000 RDPCDD RDPCDD.sys Mon Jul 13 20:01:40 2009 (4A5BCAE4) 8733b000 87343000 rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3) 87343000 8734b000 rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5) 871ca000 871f7000 rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A) a1c6e000 a1c81000 rspndr rspndr.sys Mon Jul 13 19:53:20 2009 (4A5BC8F0) 8ba30000 8ba55000 Rt86win7 Rt86win7.sys Thu Feb 26 04:04:22 2009 (49A65B16) 871c2000 871ca000 spldr spldr.sys Mon May 11 12:13:47 2009 (4A084EBB) a1ed6000 a1f27000 srv srv.sys Tue Dec 08 03:05:37 2009 (4B1E08D1) a1e87000 a1ed6000 srv2 srv2.sys Mon Jul 13 19:14:52 2009 (4A5BBFEC) a1e59000 a1e7a000 srvnet srvnet.sys Tue Dec 08 03:05:06 2009 (4B1E08B2) 8b41c000 8b41d380 swenum swenum.sys Mon Jul 13 19:45:08 2009 (4A5BC704) 8b0f3000 8b129400 SynTP SynTP.sys Thu Sep 03 20:32:25 2009 (4AA06019) 87000000 87149000 tcpip tcpip.sys Mon Jul 13 19:13:18 2009 (4A5BBF8E) a1e7a000 a1e87000 tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926) 8737b000 87386000 TDI TDI.SYS Mon Jul 13 19:12:12 2009 (4A5BBF4C) 87364000 8737b000 tdx tdx.sys Mon Jul 13 19:12:10 2009 (4A5BBF4A) 86f6f000 86f7f000 termdd termdd.sys Mon Jul 13 20:01:35 2009 (4A5BCADF) 8d6a0000 8d6a9000 TSDDD TSDDD.dll unavailable (00000000) 8b0bc000 8b0dd000 tunnel tunnel.sys Mon Jul 13 19:54:03 2009 (4A5BC91B) 8b212000 8b220000 umbus umbus.sys Mon Jul 13 19:51:38 2009 (4A5BC88A) 8b354000 8b36b000 usbccgp usbccgp.sys Mon Jul 13 19:51:31 2009 (4A5BC883) 8b40d000 8b40e700 USBD USBD.SYS Mon Jul 13 19:51:05 2009 (4A5BC869) 8bbc5000 8bbd4000 usbehci usbehci.sys Mon Jul 13 19:51:14 2009 (4A5BC872) 8b220000 8b264000 usbhub usbhub.sys Mon Jul 13 19:52:06 2009 (4A5BC8A6) 8bb7a000 8bbc5000 USBPORT USBPORT.SYS Mon Jul 13 19:51:13 2009 (4A5BC871) 8bb6f000 8bb7a000 usbuhci usbuhci.sys Mon Jul 13 19:51:10 2009 (4A5BC86E) 8b36b000 8b38eb00 usbvideo usbvideo.sys Mon Jul 13 19:51:51 2009 (4A5BC897) 86a62000 86a6d000 vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B) 872f9000 87305000 vga vga.sys Mon Jul 13 19:25:50 2009 (4A5BC27E) 87305000 87326000 VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D) 8717a000 87183000 vmstorfl vmstorfl.sys unavailable (00000000) 86abb000 86acb000 volmgr volmgr.sys Mon Jul 13 19:11:25 2009 (4A5BBF1D) 86acb000 86b16000 volmgrx volmgrx.sys unavailable (00000000) 87183000 871c2000 volsnap volsnap.sys Mon Jul 13 19:11:34 2009 (4A5BBF26) 8bb65000 8bb6f000 vwifibus vwifibus.sys Mon Jul 13 19:52:02 2009 (4A5BC8A2) 873e7000 873f8000 vwififlt vwififlt.sys Mon Jul 13 19:52:03 2009 (4A5BC8A3) 86f5c000 86f6f000 wanarp wanarp.sys Mon Jul 13 19:55:02 2009 (4A5BC956) 87326000 87333000 watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A) 8698a000 869fb000 Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28) 869fb000 86a09000 WDFLDR WDFLDR.SYS Mon Jul 13 19:11:25 2009 (4A5BBF1D) 873e0000 873e7000 wfplwf wfplwf.sys Mon Jul 13 19:53:51 2009 (4A5BC90F) 8d440000 8d68a000 win32k win32k.sys Sat May 01 10:49:02 2010 (4BDC3F5E) 8bbf6000 8bbff000 wmiacpi wmiacpi.sys Mon Jul 13 19:19:16 2009 (4A5BC0F4) 86a51000 86a5a000 WMILIB WMILIB.SYS Mon Jul 13 19:11:22 2009 (4A5BBF1A) 8b3aa000 8b3c4000 WudfPf WudfPf.sys Mon Jul 13 19:50:13 2009 (4A5BC835) Unloaded modules: a1f3b000 a1f3d000 MSPCLOCK.sys Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 00002000 a1f39000 a1f3b000 MSPQM.sys Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 00002000 a1daa000 a1dc2000 parport.sys Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 00018000 87277000 87284000 crashdmp.sys Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 0000D000 87284000 8728f000 dump_ataport Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 0000B000 8728f000 87298000 dump_atapi.s Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 00009000 87298000 872a9000 dump_dumpfve Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 00011000 872a9000 872c8000 cdrom.sys Timestamp: unavailable (00000000) Checksum: 00000000 ImageSize: 0001F000 Bugcheck code 00000051
Hi guys! I am sorry, for not writing back, I just havent had the time. But I got this fixed, I reinstalled XP, and now I haven't had a single crash in a week! But thanks for all your help!
-You can mark this as solved, Thank you.
OFFTOPIC -
my stationary PC, is having a weird problem.hosting a game, like Counter strike Source, it crashes, but before it crash, there can pass quite some time.. Sometimes by broadcasting to justin.tv with FLME (Flash Live Media Encoder) it crashes 3-5 seconds after. It is like, it crashes when much Internet upload, is being used, or much CPU, GPU or RAM is used. By crashing i mean it says like a 'drrrrrrrrrrrrrrrrrrr' sound, and i have to hard reboot. So it doesn't leave any dump files.
