Using I change to Battery Power my desktop screen changes
  1. Posts : 3
    WINDOWS 7 64
    Hi I just purchased A New ASUS notebook and every time I switch to battery power my laptop (Background) changes.. I would like to know how to stop this??
    THanks
  2. Posts : 1,180
    Windows 7 Ultimate
    When you unplug your notebook, the desktop wallpaper changes?
  3. Posts : 3
    WINDOWS 7 64
    Yes, that is correct and I want to know how to stop that??
  4. Posts : 17,322
    Win 10 Pro x64
    See if this helps,
    Power Plan Settings - Change
  5. Posts : 2,963
    Do you use the a slideshow background?
  6. Posts : 11
    It's built into Asus's bloatware. When you change the power management type, it'll change as well I take it? It does this on my Asus laptop; you just have to change the settings to use a different theme then the one you are using.
  7. Posts : 3
    WINDOWS 7 64
    Thank you Surban Atlas it was the Asus bloatware causing the problem.. Also thank you to everyone for there help with this...
  8. Posts : 2,963
    Glad you figured it out. Bloatware can cause all kinds of strange behavior.
  9. Posts : 52
    Windows 7 Professional
    I know this thread is outdated, but perhaps this reply will help others in the future.
    I had this exact issue and was looking into it. I understand that it's due to ASUS's pre-installed software - the ASUS Power4Gear Hybrid application, to be exact - but I actually do like the software, so I'm keeping it.
    However, if you have an issue with the desktop changing when the laptop is unplugged, you can do this:
    1) Go to your laptop's Power Options (in the system tray located in the bottom right corner, click on the battery icon)
    2) Click on the "More power options" link
    3) Click on the "Change plan settings" link for Power4Gear Battery Saving
    4) Click on the "Change advanced power settings" link
    5) Locate "ASUS P4G Power Setting" and click on the + sign
    6) Locate "Battery Saving Desktop" and click on the + sign
    7) Next to "On battery," select "Disable"
    8) Click the Apply button, click the OK button, then close all the windows you opened
    Now when you unplug your laptop, it should no longer change the desktop settings.
    Hope this helps!
    Vic
