Windows 7: Gadgets problems: All cpu meter, network meter and ilMeteo not work!
05 Oct 2010   #1
DLz
Hello!
I also have problems with this gadget. I install it, but do not charge anything. It remains a white box that shows the following thing: <! . It is not the only gadget I have problems with: Network meter also does not load and shows the same thing: <! . Another gadget that I have problems with it is ilMeteo, but the problem is different. Here is a screen of my desktop:
1 is the gadget ilMeteo, 2 is the gadget of all cpu meter and 3 meter network. Of course I installed core temp. Apart from these gadgets, the others all work (so far).
Here's how I tried to solve the problem:
I used the command prompt type the following commands (Open an advanced command prompt -> choose Run as administrator Type the following and press Enter after each):
regsvr32 msxml3.dll
regsvr32 scrrun.dll
regsvr32 jscript.dll
Restart PC, it did not work
I used WinFix: Restore the Windows Sidebar and restarting, but it did not work
I disabled the UAC and it did not work
I have done scandisk and even this worked
I edited the registry entry Sidebar, giving all permissions to my account but even that worked!
What can I do?! This problem may be due to the fact that having a monitor 23 "use a resolution of 135 DPI?
Thank you all!
07 Sep 2011   #2
rdajunior95
I have the exact same problem.
Can anyone help?
09 Sep 2011   #3
kewl1
Win 7 Ultimate SP1 64 bit
Gadget Problem
I don't think it is a monitor problem. The one I have on my Blackbird with a large Dell monitor is still fine. It's my Thinkpad laptop that it stopped working on after more than 2.5 years. My problem is the same as everyone else who has described it here. It is only with the one gadget and I have tried all the suggested fixes. So I guess it is goodbye forever to ALL CPU Meter you piece-o-crap
09 Sep 2011   #4
Brink
64-bit Windows 10 Pro
Hello,
You might see if this may be able to help fix this issue for you.
Gadgets not Displaying Correctly in Windows 7 - Fix
11 Sep 2011   #5
rdajunior95
Tried it and it is still not working.
11 Sep 2011   #6
Brink
RDA,
Is it a specific, some, or all gadgets this is happening with? Could you post a screenshot of this to see if anything may stand out?
11 Sep 2011   #7
rdajunior95
It turns out, all the gadgets from this website are not working - Most Wanted Windows Gadgets - Windows Vista and Windows 7
12 Sep 2011   #8
rdajunior95
I have a 64 bit OS. Does that mean I have to change the commands when I run the elevated cmd?
If so, can anyone tell me what commands do I have to enter.
12 Sep 2011   #9
Brink
No, the commands in the tutorial above work in both 32-bit and 64-bit Windows 7. The problem seems to be as you said with that website and it's outdated gadgets on it. You might see if you may be able to find the gadget you wanted from here instead. They should work for you without issue.
Desktop and SideShow gadgets - Microsoft Windows
12 Sep 2011   #10
rdajunior95
Still not working
1 meter or 2 meter led strip ?
I`m guessing for the money, a 2 meter strip would be best ? NZXT Premium Sleeved LED Kit (2 meter) - White at Xoxide!
PC Custom Builds and Overclocking
network meter not working?
I just downloaded the network meter gadget, however it does show anything, everything is at 0.0000bit/s however it does detect my ip address etc. What is wrong?
Customization
network meter gadget doesn't work!
hi see the picture! my nework adaptor card not shown on gadgets!:( but my connection to internet is ok I tried this(https://www.sevenforums.com/tutorials/140358-gadgets-not-displaying-correctly-windows-7-fix.html) but didn't help me
Customization
Problem with network meter
Hello all,i have a problem with my network meter gadget. I deleted id,installed it again and again,tryed different versions...doesn't work.I just love this gadget,small and very usefull. http://www.sfkilla.com/gads/networkmeter.jpg And here is how my gadget looks. Can i solve it or...
Customization
Free - Network Bandwidth Meter x86/x64
Networx is a very light-weight and powerful network monitor tool for Windows 7 x86/x64. Much like DUMeter, it has many logging functions or can simply be used to quickly determine network activity. I've used it since v5.0 and have found it to be very stable and reliable. It also fully Aero...
Software
