#41
waiting it scans finished, later i will restart it, and c wat happening
if got items infected, what action should i take
if whatever infections you got replaced/damaged system files, you may need your win7 dvd. aside from that, the default function of your antivirus should be to remove the infection. if it says it cant be removed, then quarantine the files.
Trying following Anim's advice! Worked for me!
https://www.sevenforums.com/gadgets/1...ml#post1069596
i settled my problem already, thanks to anim and also kword88 who had provided me many suggestions to solve my problem although it din work, thanks u all
