gadget problem. please help me!!!
Page 5 of 5 FirstFirst ... 345
  1. Posts : 36
    window 7 Home Premium 64 bit
       #41
    waiting it scans finished, later i will restart it, and c wat happening
  2. Posts : 36
       #42
    kword88, do u have msn?
  3. Posts : 36
       #43
    if got items infected, what action should i take
  4. Posts : 525
    windows 7 ultimate 64bit
       #44
    if whatever infections you got replaced/damaged system files, you may need your win7 dvd. aside from that, the default function of your antivirus should be to remove the infection. if it says it cant be removed, then quarantine the files.
  5. Posts : 2
    Windows 7 Ultimate
       #45
    Please, I have same problem, did you find solution ?
  6. Posts : 10
    Trying following Anim's advice! Worked for me!
    https://www.sevenforums.com/gadgets/1...ml#post1069596
  7. Posts : 2
    Windows 7 Ultimate
       #47
    Thanks man, its OK now
  8. Posts : 36
       #48
    i settled my problem already, thanks to anim and also kword88 who had provided me many suggestions to solve my problem although it din work, thanks u all
