Problem with desktop icons selection
  1. Posts : 5
    WIn 7 x64
    I can't select some icons on my desktop. When I move cursor over icon it looks like this:
    After clic it looks like this:
    What to do?
    Attached Thumbnails Attached Thumbnails Problem with desktop icons selection-untitled-1.jpg   Problem with desktop icons selection-untitled-2.jpg
  2. Posts : 12,120
    Win 7 Pro x64 / Win 10 Pro
    Welcome to the Seven Forums
    Is it doing it on all icons or just the one you are showing?
    If this is a recent problem you could try a System Restore to a time before this started.
    You may want to download and let it update and run a full scan with Malwarebytes : Malwarebytes Anti-Malware PRO removes malware including viruses, spyware, worms and trojans, plus it protects your computer used the free version.
    You may also want to do Option 2 in this tutorial SFC /SCANNOW Command - System File Checker This will not harm any data or programs you have installed it will try to repair any corrupt system files.
    When done with the above you may want to Icon Cache - Rebuild
    Jerry
  3. Posts : 5
    WIn 7 x64
    Thank you! I will try it.
  4. Posts : 53,363
    Windows 10 Home x64
    If you left click on that icon and drag it, does it drag just the one icon, or a group? A Guy
  5. Posts : 5
    WIn 7 x64
    I can only drag one, middle one. I do not have acces to 3-4 icons on left and right unless i will drag middle one somwere else.
  6. Posts : 53,363
    Windows 10 Home x64
    Is that the programs original icon? I would delete the shortcut (I am assuming it is a shortcut?), and create a new one. It appears that somehow the icon is displaying as if it were wider, although it doesn't move the icons around it out of the way. You might try right clicking the desktop, choose View and change the icon size around, then back to desired, and see if it helps (it may change the spacing and you'll have to move them back). First I'd try rebuilding the icon cache.
    A Guy
  7. Posts : 5
    WIn 7 x64
    This happens to all kind of icons and folders on desktop. How to change spaces between icons in Windows 7?
  8. Posts : 5
    WIn 7 x64
    Also I found that all texts under icons are in one line, long names too. ???
