I don't know what problem im going though... please have a look :(
Page 1 of 3 123 LastLast
  1. Posts : 16
    Windows 7 home premium x64
    Problem is why when i click my folder..the icons loads from left to right? it should be after i click in.. the icons are already there but.. now the icons comes out from left to right. Please help me, i have already uninstall all my themes but its still like this
  2. Posts : 15,026
    Windows 10 Home 64Bit
    Welcome to the forum.
    See if any of these tutorials help.
    Folder View - Reset All Folders
    Folder View Settings - Reset All to Default
    Post back for further suggestions.
  3. Posts : 16
    Doesn't work. It still coming out from left to right
  4. Posts : 15,026
    Do you remember how you enabled this effect?
    Try SFC /SCANNOW Command - System File Checker and reboot if it finds violations.
  5. Posts : 16
    i didn't enable it, it happen just like that
  6. Posts : 15,026
    Alright.
    Did you do the sfc scan?
  7. Posts : 16
    koolkat77 said:
    Alright.
    yea it says there's some error with CBS.LOG something, i restart my pc. But the problem is still there.. i tried scannow but it came out it says ''Windows Resource Protection could not perform the requested operation''. Just now i just use sfc /verifynow
  8. Posts : 15,026
    Create a new user profile and see if that effect is present in the new user.
    User Account - Create
  9. Posts : 16
    Even the other profile also the same-thing mate.
  10. Posts : 15,026
    Try a System Restore to a point when you remember your icons weren't behaving like that.
