27 Apr 2017 | #1 |
Can i run my laptop on AC power (without removing the battery) ?
I always use my laptop directly on AC power (removing the battery) unless I am travelling or there is no source around. But can i run it on AC power without removing the battery and when AC power turns off the laptop automatically going to run on battery ?
My System Specs![]() |
27 Apr 2017 | #2 |
If I understand the question set correctly, yes, your laptop can run just fine with the battery inside and the AC cord plugged in. I think what happens is that the AC cord is charging the battery at all times while the battery powers the laptop at all times.
If you unplug the AC cord, the battery simply continue onward. |
27 Apr 2017 | #3 |
Can i change that and let AC cord powers the laptop at all times (without removing the battery) ? and when the electricity turns off the battery automatically going to powers the laptop.
27 Apr 2017 | #4 |
I don't believe laptops will work any other way...let's ask others here in the know.
17 May 2017 | #5 |
This is the natural flow of events for a laptops the battery is generally not intended to be removed. Some new laptops don't even give you access to the battery or HDD anymore unless you remove the entire real cover.
Your choice:
18 May 2017 | #6 |
Battery required
18 May 2017 | #7 |
Thank you very much guys for the info, appreciate the support. Much love to all of you
Thread Tools | |
Similar help and support threads | ||||
Thread | Forum | |||
laptop freezes periodically after removing battery Greetings, I recently downgraded from windows 10 to windows 7. After the update, whenever i remove the battery, my computer freezes periodically. Whenever i put the battery back in, it works absolutely fine. no freezes. i have disabled the battery charging, as i dont want to ruin the battery. I... |
Performance & Maintenance | |||
DELL E6530 Event 41, Kernel-Power on battery power Hi, Am new here but long-time Windows uses since Win95. Currently have a DELL E6530 and it gave me a BSOD Event 41 Error while on batteries! Looking around Google and other forums, this transpires to be a PSU related problem, but it's a laptop, and was running on batteries at the time the BSOD... |
BSOD Help and Support | |||
I have no sound when my laptop is on battery power It goes like this: my laptop is normally plugged in, high performance power settings, battery taken out. Every once in a while I put the battery in and use it with normal charge/discharge cycles, power saving settings. Now it somehow happened that when I put the battery in and windows booted up I... |
Sound & Audio | |||
BSOD After Replacing Battery on Laptop, Power Driver Failure I've read around a bit but nothing seems to be fixing my problem. My battery on my laptop died a few months back. I got the battery replaced last month and ever since I've been experiencing the BSOD for power driver failure once or twice a day. It rarely occurs while the laptop is in use. It's only... |
BSOD when running laptop off battery power About 4 months ago I performed a number of upgrades to my 4 year old Lenovo SL400 laptop. I upgraded to a Seagate Momentus hybrid drive, upgraded my CPU, installed new RAM, purchased a new 9-cell battery and performed a clean intstall of Windows 7 Home Premium 64-bit (the computer came with... |
Our Sites |
Site Links |
About Us |
Find Us |
© Designer Media Ltd All times are GMT -5. The time now is 09:58. |
