Niggly Problem with shortcut arrow and pin to taskbar
  1. Posts : 410
    Windows 7 RTM x64
    Hi all
    I have a small issue, i have looked around and cant see obvious answer. Whenever i remove the shortcut arrow of icon i can no longer pin to the taskbar. Ive had this in all builds ive tried. To pin to taskbar i have to re-enable the arrow lol
    Has anyone else had this problem and if so where you able to overcome it. Only reason it bugs me now is cos i bought a new 24 inch monitor and all of a sudden the arrows look huge lol, and i like having biggish icons on the desktop
    Any help would be gratefully recieved.
    Regards
  2. Posts : 72,062
    Hello Damoh,
    It's not the same thing, but if you really do not want the shortcut arrows, you may be able to create a toolbar on the taskbar for the folder instead like how it was done for the Quick Launch folder in this tutorial below.
    Quick Launch - Enable or Disable
  3. Posts : 410
    Windows 7 RTM x64
    Mate, thats fantastic thanks much respect
  4. Posts : 72,062
    You're welcome Damoh. I'm happy to hear that it will work for you.
  5. Posts : 358
    windows 7 HP 64bit
    Can someone tell me how to get rid of the arrows please.
    with XP i normally use TweakUI but it doesn't work with W7.
    Thanks.
    Dave.
  6. Posts : 4,282
    Just use this and follow the instructions, put the blank icon in the windows directory and use the remove arrow (c) if you have your OS on c drive which most people do. once you apply the registry setting log off and log on again to see the changes.
    https://www.sevenforums.com/tutorials...e-restore.html
    Niggly Problem with shortcut arrow and pin to taskbar Attached Files
  7. Posts : 358
    windows 7 HP 64bit
    Mr Grim you did it again.
    Have another beer or two.
    By the way, any idea why I cant give you any rep? I tried, honestly.
    Dave.
    EDIT: Wait, i was trying to do it form your sig, i didnt see the button above the post. all sorted now. Cheers.
  8. Posts : 4,282
    Glad it worked for you and I will have another beer as well
    Not sure why you can't give me rep unless you have given it to before and you have not given rep to enough people since then.
  9. Posts : 410
    Windows 7 RTM x64
    Spot on mate!! Worked even better for me. Muchos reps os
