System Icons Problem
  1. sid
    Windows 7 32bit
    Hello, I'm new here on the forums,
    I have an issue with the system icons ..
    I cannot turn on the network icon .. its turned "OFF" and marked grey .. so I can't edit this one, I've tried alot of ways to get it back but it still won't help .. anyone has this problem or knows how to solve this one ?
    cheers !
  2. Posts : 72,062
    Hello Sid,
    Check in the registry at the locations below to see if you have HideSCANNetwork in the right pane. If you do, then delete it. You can also use METHOD THREE in this tutorial.
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    and
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
  3. sid
    Windows 7 32bit
    Thanks Shawn, but it still not worked, tried every step ..
  4. Posts : 72,062
    Some say that restarting the computer a few times restores it as well. May be worth a try if you haven't already.
  5. sid
    Windows 7 32bit
    and how many times exactly ? i've been doing this about 20x today ..
    i've already tried reinstalling the drivers as well .. deleting and reinstalling..
    hopeless
  6. Posts : 72,062
    Sid,
    It's usually only a couple of restarts instead. You might consider a System Restore using a restore point dated before this problem to see if it can help.
  7. sid
    Windows 7 32bit
    ok thanks
