Twinhan DVB card driver works in Vista 64bit but not 7 64bit HELP HELP
  1. Posts : 13
    Windows 7 Ultimate 64bit
    Hello
    I have a DVB card called Twinhan 1025
    Twinhan company is gone so they dont provide new drivers
    the driver we have is for Vista 64bit which works well with RAM more or less than 4 GB but in Windows 7 64bit it works with only RAM less than 4 GB
    My RAM is 6 GB when I boot normally I am able to get the signal level and quality but cant add channels or view them
    when I set the boot option the limits the memory to 4000MB I am able to view or add new channels
    This is not a software issue
    cause I have tried programs in compatibility mode and as administrator
    and download viewers for 64bit OS and for 32 bit OS
    So it's a driver problem or Windows 7 problem
    Now can I do something to make Windows allow this driver to map specific range of memory ?
    Please help with any solution cause the workaround of limiting the boot memory isn't a practical one
    I even tried to install VM's and install Windows XP but they do not provide access to PCI slots
  2. Posts : 13
    Up!
  3. Posts : 13
    up!
