Windows 7: USB 3.0 HUB speed problem
04 Apr 2011   #11
sygnus21
Windows 10 Pro
Then I would suggest you call Aluminous and find out what's going on. Good luck.
04 Apr 2011   #12
Sardonicus
Windows 7 Home Premium 64 bit
Quote   Quote: Originally Posted by Commodore Pet View Post
I just purchased a Ultra Aluminous 4 port USB 3.0 Hub.
My computer has been relocated and it is now very difficult to get at my 3.0 ports on the back of the machine so I thought this would make life easy.
My latest Renesas USB 3.0 driver software sees the new hub as USB 2.0 and installs that driver. I have 2 USB 3.0 drives that work fine if plugged directly into the back ports, but if I plug them into my new hub I get a message telling me they can go faster.
Is there a way to manually install the USB 3.0 hub driver? I believe the Renesas driver package includes it. I tried using device manager manual install but it does not list Renesas drivers when it lists all available drivers.
I have tried removing and re-installing the latest driver software with no luck.
Hello,
is your hub is plugged into the USB 3.0 ports on the back?
If not and you've plugged the hub into one of the USB 2.0 ports, then the hub will operate at 2.0 speeds.
04 Apr 2011   #13
Commodore Pet
Quote   Quote: Originally Posted by p5bdkw View Post
Hello,
I have tried both of my USB 3.0 ports
04 Apr 2011   #14
Commodore Pet
I have also updated to the latest driver and firmware that I can find.
04 Apr 2011   #15
Sardonicus
Have you turned off the PC with the HUB on
and allowed Windows 7 to re-initialize after start-up?
04 Apr 2011   #16
Commodore Pet
Quote   Quote: Originally Posted by whs View Post
But as things are it definitely looks like a driver problem. I would call the company and ask them what they suggest.
I called Ultra tech support and they told me I had done everything they could think of and to just return it. I am hoping someone on this site will think of something I have missed. If not, by Wednesday, I will look into returning it.
04 Apr 2011   #17
sygnus21
Windows 10 Pro
Honestly looking through the post it looks like you've done everything you should have done. And if tech support can't give you any other advice, than yeah, return it.
Actually there is one question? Is you motherboard 3.0 compliant? You mention the renesis drivers so I assume it is, but I have to ask.... just in case.
Actually I just Googled it and it appears it is.
04 Apr 2011   #18
Sardonicus
As long as you've plugged the hub into the Blue ports, then you've done all you can do.
Good luck.
19 Mar 2012   #19
RAFAE30
a lot of them
Hello sorry for my bad english.
You can try in win 7 32 bits and works ok. In 64 bits there are a problem a donīt work at 3.0 velocity.
Just belive me, i tried this in a second partition with 32 bits and works fine.
19 Mar 2012   #20
Commodore Pet
Quote   Quote: Originally Posted by RAFAE30 View Post
Thanks. I only have 64 bit installed but at least it gives me something to go on.
Problem with USB speed
Hi everyone. I am having a major issue with slow USB speeds (1.30MB/second usb 3.0). I thought I had solved it but apparently not. Slow speeds occur on every USB port. I have attached a screenshot of my device manger and the usb ports that are no my system. Note: I have no hubs or anything...
Hardware & Devices
Internet Speed Problem
Over the last 3 or 4 days my wireless connection has started becoming very slow and oddly it uploads faster than it downloads at th moment. I have tried scanning with MBAM which reports its clean and I have laso used SuperAntiSPyware which cleaned a couple of items and now says that it's clean....
Network & Sharing
Internet speed problem
My internet speed is 256 kbs (download) when i go to speedtest it shows that my speed is 1.8 mb/s My ISP sais that it should be 2048kb/s But its never over 250kb/s NEED HELP!!:cry: Its a ADSL(broadband)connection with modem: Paradigm PTI-8411 Annex A (its from ISP) and TP-Link wireles...
Network & Sharing
Odd speed problem behind a router
This is from my last post moving to the next confusing problem. My customer has 4 computers hooked up to his router. The customer recently got his line repaired and is hooked right up to his node directly outside his house. Going right to his modem he gets 60mb. Once he hooks up to his router...
Network & Sharing
Speed problem
Hey there I'm subscribed to 8mb/s connection. There's no connectivity issue, no disconnects but the porblem is speed. My few YouTube videos buffer, downloading speed normally from sites is 200-300 kb/s. Only few sites like Ubuntu, Microsoft sometimes gives me full speed. Is there any problem with...
Network & Sharing
Đ Designer Media Ltd
