Sound distortion problem when wireless is on
  1. Posts : 8
    From around one month or so i am having sound distortion problem in between playback of music, movies and even during gaming, the mouse pointer also stucks when this distortion comes, but when i turn my wifi off the distortion is no more.
    I have tried reinstalling my wireless drivers, It is Intel r wifi link 1000 bgn and no new driver version is available from Dell's website.
    Also the cpu performance graph reaches top when distortion occurs.
    I have also updated to the latest BIOS.
    Please help guys, sound distorts once in a minute.
    I have 4 gb of RAM with i5 processor, laptop model is Dell inspiron N5010.
  2. Posts : 3,960
    W7 x64
    Try turning down the Tx/Rx power level in your WiFi adapters advanced properties tab...
  3. Posts : 8
    tx/rx is already down to the least which is 20%.
  4. Posts : 3,960
    W7 x64
    Try the latest drivers for your WiFi adapter from Intel's website would be the next logical thing; but remember this will most probably reset the devices properties to default values.
  5. Posts : 8
    already tried that, the one installed on my laptop is the latest one.
  6. Posts : 3,960
    W7 x64
    Can you try an alternative WiFi card; either the same one, or another type?
  7. Posts : 8
    does that means that my wifi card is having the problem and needs to be replaced?, my laptop is currently in warranty and should i contact Dell..??
  8. Posts : 3,960
    W7 x64
    Not necessarily, it's a process of elimination...
  9. Posts : 8
    Ok thanks and what about reinstalling my OS, will that help??
  10. Posts : 3,960
    W7 x64
    I can't think of how your OS is causing physical radio interference.
    The probable cause is the WiFi card; but that said it could be an assembly fault whereby a sound cable has been inadvertently laid close to the WiFi cards antennae pigtails...
    If it were me, and if I didn't have an alternative WiFi card to hand, I think I might call Dells technical support line...
