Using a wireless usb device that need Atheros drivers.
  1. Posts : 9
    Problem is that I'm on Windows 7 but it keeps automatically installing drivers from 2008 that are for Vista. I think this is one of the reasons I'm getting BSOD problems..
    EDIT: And now it's saying they weren't installed correctly. I'm beyond confused...
  2. Posts : 4,466
    Windows 10 Education 64 bit
    Have you looked on the manufacturers web site for drivers? Did the wireless adapter come with an driver/software install CD?
  3. Posts : 9
    Yeah but the CD was for Windows XP only. I looked on the website and they do have drivers for Windows 7 but when you install them, the date for them is 2008... they work, but I just figured that's where this BSOD probably is coming from.
  4. Posts : 4,466
    I see you started a thread on your BSOD but did you look at this first?
    https://www.sevenforums.com/crashes-d...tructions.html
  5. Posts : 9
    Yes and I posted the thread according to those instructions.
  6. Posts : 4,466
    OK, if you can't find a better driver you may have to buy a better wireless adapter. Or switch to a wired connection and uninstall the wireless adapter.
İ Designer Media Ltd
