[HELP] "No Audio Output Device is Installed"
Page 4 of 9 FirstFirst ... 23456 ... LastLast
  1. Posts : 44
       #31
    done installing windows 7 ultimate using USB flash drive bootable, i followed the tut from the link you gave on how to make USB flash drive bootable, the installation done smoothly and accordingly, but after fnished installing new OS(clean install), still no sounds and cant connect via LAN cable broadband, i think the device for sound was damaged and doesn't work properly, but never mind the sounds, all i want right now is to get back my DVD ROM, it doesn't in "My Computer" and at "device manager",
    im sorry sir for the inconvenience and thank you for your time to answer all my questions,
  2. Posts : 21,004
       #32
    It's no inconvenience Think but as there are only drivers for Vista on that HP site there are just two things you can do one is to contact HP them selves in your locality or just down load the 64bit Vista drivers.
    If the drivers still make no difference then something else might have to be tried. http://h20000.www2.hp.com/bizsupport...dTypeId=321957
  3. Posts : 44
       #33
    hope that one works in w7u.64bit, i will try it tomorrow when im back home, thank you sir, highly appreciated,
  4. Posts : 44
       #34
    oh everytime i open my laptop, theres a lot of windows update, is it ijmportant?, or mandatory to do the updates?, i've attached the some"windows update history", the last one "Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2836942)", make my laptop freeze at "Windows Starting", whats the use of that ".NET blah blah" thing do?,
  5. Posts : 21,004
       #35
    Yes they are mate as some might be to do with your drivers and software anyway. But make sure you look at them first and do them in small batches so that if you need to system restore there will not be a flood again:)
    Let us know how you go.
  6. Posts : 44
       #36
    this the new updates, is this okay to download this batch of updates?, im afraid, what if they cause my system to freeze/hang again
  7. Posts : 21,004
       #37
    The ones you have circled are ok I am just curious as to why you have all those refs to SP1?? because if the Windows is a new version it would have SP1 with it. So is it a retail or an OEM you bought and not wanting to sound rude but why Ultimate??
    In any case if it does freeze then do a system restore via the safe mode.
  8. Posts : 44
       #38
    no sir my friend just downloaded the OS installer i dont know if it retail or OEM, but what should i do to know if it is retail or OEM?
  9. Posts : 44
       #39
    If the drivers still make no difference then something else might have to be tried. HP Pavilion dv9700 Entertainment Notebook PC series - Download drivers and software - HP Business Support Center
    sir its not available anymore
  10. Posts : 21,004
       #40
    Think try tis one mate but BE CAREFUL what you pick and watch out for ads and do not use any PC cleaners that may come along. https://www.slimwareutilities.com/slimdrivers.php
    The version of Windows is beginning to sound suspect I cannot remember asking you to but if I did a I am sorry but download Speccy Speccy - Download
    download this from piriform and run check the Operating system line and send a screen shot .
    Do this first.
    PS run this too and return Windows Genuine and Activation Issue Posting Instructions
