Ethernet Problem - Help!!!
  1. Posts : 179
    ive just formatted my pc (windows 7) the eithernet driver wasnt in stalled so ive gone on my other pc and downloaded the driver ive gone to install it but i get a deep sleep error.
    my motherboard is ASUSTeK Computer Inc. -Support- Drivers and Download P8P67
  2. Posts : 1,449
    Windows 7 ultimate 64-bit
    Can you post the exact message you get and also post any event viewer error messages
  3. Posts : 5,915
    Windows 10 Pro X64
    Also try using the drivers on the disc that came with your motherboard
  4. Posts : 18,415
    windows 7 home 64bit
    Hi there .. Is the Network Card missing in the Device Manager ? Unplug the power cable press the start button for ten seconds ... Then check in your BIOS that the card is enabled ..
