7077 C drive not accessible problem
  1. Posts : 30
    Vista
    Hello,
    I've had a new problem on my 7077 installation.
    Although my pc is running fine, when I try to click on my c drive, it says that it's not accessible.
    There is therefore no information shown for it in terms of size, or or free space.
    Even when logging in as an administrator, I cannot access it.
    EDIT - I cannot even access my DVD drive, although I can access my D partition...
    All was working fine until earlier this morning - and no, I haven't visited any 'dubious' sites recently
    Any advice would be greatfully received!
    Very Best Wishes,
    Bob.
  2. Posts : 4,925
    Windows 7 Professional 64-bit
    Why arent you running RC?
    It sounds like you used the upgrade install method from a previous build and I would therefore recommend a clean install to RC.
  3. Posts : 30
    Vista
    Hello,
    I hadn't got as far as installing to RC due to workcommitments etc.
    Unfortunately, I cannot install from a dvd as it cannot access the C drive!
    The strange thing is, I'm typing this in Opera, which IS running from my C drive.
    You're correct, each time, from 7000 upwards, I have upgraded Windows.
    When I have previously opted to clean install, I always see folders from the previous installation, included in the C drive - I don't mean windowsold...
    Very Best Wishes,
    Bob.
  4. Posts : 4,925
    If you have a usb drive you might want to try followting this guide: USB Windows 7 Installation Key Drive - Create
    If you do a clean install then you shouldn't have been seeing windows.old. That only appears with an upgrade install.
  5. Posts : 30
    Vista
    Hello,
    I should have made myself a little clearer, I meant to say that I see previous folders from installed programs, such as the ATI folder etc, and not windows.old.
    Very Best Wishes,
    Bob.
  6. Posts : 4,925
    you could try running "scf /scannow" to see if that fixes any errors.
  7. Posts : 30
    Vista
    Thanks swarfega, how do I run that?
    Bearing in mind that I don't seem to have ANY administrative rights (even though I also have enabled the Administrator account!)
  8. Posts : 4,925
    in the search box in start menu type "cmd", once that is open then type in that command. You should right click on the cmd that comes up listed in start menu and select run as administrator.
  9. Posts : 30
    Vista
    Hello,
    I've tried, but Windows cannot run cmd from the start menu as it says that
    cannot access it, and that there might be a problem with the network.
    Bearing in mind that the C drive doesn't show any info at all, nor is accessible by clicking on it, I'm wondering if it's a firewall problem?
    For info, I'm using Comodo Firewall.
    I can access pictures on my desktop, but cannot drag them onto my D partition. I can open them in paint.net (for example) and save them to D...
    Very Best Wishes,
    Bob.
  10. Posts : 30
    Vista
    Hello,
    Just a quick update, I cannot access the DVD drive, but I can access a USB flash stick...
    Would installing from a dvd over an external usb dvd drive work?
    Very Best Wishes,
    Bob.
