problem with explorer.exe on startup also dvd rom problems
  1. Posts : 5
    se7en 7000
    hello everyone, as i have been enjoying windows 7 since the 6956 build and even then i had these problems:
    on startup explorer only seems to halfway start, i have to end the xplorer process then start a new explorer task to get the computer to boot.
    also the dvd drive doesnt allways work, it just kinda dissapears every once in a while.
    other than that i am digging this new os, looks like microsoft is trying to fix vista. woot!
    if anyone knows how to fix these issues please let me know, if i can get these fixed then i will be able to switch to 7 tottaly :)
  2. Posts : 2,899
    is this a fresh system???
    what software did you install??
    if it is a fresh system then what hardware do you have???
  3. Posts : 154
    Windows 7 Build 7100
    Well I have been encountering a problem with explorer when I goto Computer and then it freezes or something. Then I have to kill the task, after that the Control Panel or anything that required explorer will not open. Even if I kill explorer.exe process and start it again.
    I thought this might have had something to do with Virtual Clone Drive so I uninstalled it and we will see if that makes a difference now. Any suggestions what to use for mounting iso's?
    Oh Did I mention this is on build 7000 on my Dell M1330 XPS Laptop. , I guess I should update my info. lol
  4. Posts : 2,899
    use iso disk...
    its here in the free programs for windows 7 sticky
  5. Posts : 5
    se7en 7000
    i have vista on one partition, this is a brand new laptop and i installed 6956 on the other partition and i started having this problem i continued testing 7 with everything else i could, and all seems to work well except for these things, i havnt done anything out of the ordinary to this OS. does having the 2 different paritions messing with my explorer.exe? i thought there were two different ones on each partition
  6. Posts : 2,899
    nothing like that will happen...
    what i am more interersted is in what hardware you have installed and if you have any usb devices plugged in when this happens??
  7. Posts : 5
    se7en 7000
    no usb devices on bootup, its a laptop so nothing is plugged in, i wonder if i can set up a scheduler to restart explorer after it starts and that might be a good work around but i think that explorer has to be fully running in order to schedual anyting like that
  8. Posts : 2,899
    then what model laptop is this???
    you can actually do that but wouldnt explorer restart??
  9. Posts : 5
    se7en 7000
    asus m50
    ASUSTeK Computer Inc.
    i thought that explorer was the first to load, then the schedualer or startup folder gets ran, if i could get the startup folder to run i could dosome old school bat files and make it run once to restart explorer, but i think explorer will have to be running completely before that can happen
  10. Posts : 2,899
    actually you can
    this is temporary fix...
    taskkill /im explorer.exe
    %SystemRoot%\explorer.exe
    save it as a bat file
    have you had any notices on driver updates
    or did you install vista's??
