Windows 7: HELP ME please!!! OS not genuine Help Help me,Amigos
07 Dec 2010   #11
Abhishek Ghosh
Windows 7 Ultimate 64 bit, Mac OS X 10.6
As Bill nicely wrote; you have no other way other then:
Option 1. To format your PC after copying the documents, videos, music or other files you need to use and have no copy other than in HDD. Though, if you format and install Win 7 on the same partition, all your documents will be in that partition as Windows.old, but it is better to take a frank copy paste/ burning to dvd/cd (may not be applicable for you).
Format your Netbook using the media came with (if so) your netbook. You have to enter the COA key on the back of your computer and activate. (as Bill already said).
If you have purchased a branded notebook (most probably you have), but have no disk; you must contact your system manufacturer.
Warranty most probably will not cover the charge though.
Option 2. Buy a retail copy of windows 7 Ultimate if you want to use ultimate or Home Premium.
07 Dec 2010   #12
Hopalong X
Ooops! My bad Yowanvista.
07 Dec 2010   #13
Hopalong X
If this works I translated the Repair install tutorial.
Casa 747
Click this link.
Si esto trabaja traduje la reparación instalo clase particular.
Casas 747
Usted necesitará utilizar su disco de Windows 7.
Chasque este acoplamiento.
www.sevenforums.com/tutorials/3413-repair-install.html - Translator
07 Dec 2010   #14
Kari
First, welcome to the Seven Forums, Casa747.
If I have understood you correctly, I think you can not use repair install. When upgrading Windows with Anytime Upgrade, the operating system is upgraded. Repair install works as an in-place upgrade to the same operating system, replacing system files, and you can not in-place upgrade for instance a Home Premium or Professional with Starter.
The same thing with system restore. I've only done Anytime Upgrade once but as far as I can remember, doing this deleted the earlier restore points.
In my opinion your best chance to get everything back as it was is to reinstall Starter either from recovery partition, or from DVD using external hard disk.
Two questions: Can you, or your brother maybe, use BIOS to change the boot order (orden de inicio) of your netbook? Do your netbook have a partition named "Recovery"?
And please, could you tell us the name and exact model of your netbook.
Kari
07 Dec 2010   #15
Abhishek Ghosh
Quote   Quote: Originally Posted by Kari View Post
You are 100% right. Plus his brother may actually have downloaded a crack, which may have malwares ; so, it is better to format (plus use Antivirus + Antimalware checking).
07 Dec 2010   #16
Hopalong X
Quote:
En primer lugar, Bienvenido a los foros de siete, Casa747.
Si le he entendido bien, creo que no puede utilizar la instalación de reparación. Al actualizar Windows Anytime Upgrade, se actualiza el sistema operativo. Reparación instalar obras como una actualización in situ el mismo sistema operativo, reemplazar archivos de sistema, y usted puede no en el lugar de actualización para la instancia de un Home Premium o Professional con Starter.
Lo mismo con la restauración del sistema. He sólo hecho Anytime Upgrade una vez, pero en lo que respecta a puedo recordar, haciendo esto elimina los puntos de restauración anteriores.
En mi opinión es su mejor oportunidad para obtener todo atrás como lo fue reinstalar el inicio de la partición de recuperación, o de DVD con disco duro externo.
¿Dos preguntas: puede usted, o su hermano tal, utilice BIOS para cambiar el orden de arranque (orden de inicio) de su netbook? ¿Hacer su netbook tiene una partición denominada "Recuperación"?
Y por favor, podría decirnos el nombre y el modelo exacto de su netbook.
Kari
Tranlsted Kari.
If you "blue" select your posting and right click as you would for copy you may have as I do Bing Translator listed.
Click and in new Window you can translate by selecting "To Spanish". Copy and Paste back as I did Kari's posting.
Then you have English and Spanish version to post.
Mike
07 Dec 2010   #17
Kari
"Los foros de siete" :)
07 Dec 2010   #18
gregrocker
Microsoft MVP
Look in All Programs for Recovery, possibly under the maker's name. Select it to run Factory Recovery. Back up your files first.
You should also be able to run Factory Recovery from the first boot screen, by tapping the key given to Run Recovery. If it is not made clear on the first boot screen, look in your Manual on the SUpport Downloads webpage for your model.
Where did you get the Win7 Starter OEM Installation DVD? Has it been used before so you know it works?
Try extracting the ISO from the Starter DVD using ImgBurn, then write it to flash stick to use as a bootable installer. The easiest method is to install free UltraISO trial: On file tab Open ISO, on Bootable Tab, Write Disk Image, Format, then Write.
Now boot the stick using the one-time BIOS Boot Menu, or set the flash stick (sometimes listed under Hard Drives) in BIOS setup as first to boot, before HD.
08 Dec 2010   #19
casa747
window 7 starter 32bit
Thx,i know about it. But,what is puzzle me now is when "setup is starting" then install.win problem and error code 0x8007000D. Maybe that file not correct image or what?. I check in my HDD install.wim is exist and that file is largest size. I try open install.wim use 7-zip,but only have {1}.xml file.
08 Dec 2010   #20
casa747
ouh..i see
Another non genuine copy of Windows that is in fact genuine problem
There was a 5 page thread on trying to downgrade from Ultimate to Win 7 Pro but I thought I should start a new thread. I have a thead on a different forum but was hoping someone here might know the answer. Users computer says Windows is not genuine, was 7 pro, in Sept 2013 we upgraded to...
Windows Updates & Activation
Genuine state set to non-genuine (0x00000000) for application Id 55c92
My computer (from lenovo) came with windows 7 (home). Because I run a domain within my lan, I purchased and downloaded windows 7 64 bit professional. Today I downloaded and ran System Mechanic pro (trial version) from Iola site. After running it and rebooting, my system shows that the system is not...
laptop says copy of windows 7 not genuine but it is genuine
Recently a note has appeared on bottom right of screen on my laptop which says-This copy of windows is not genuine. I know for a fact it is genuine as i only purchased it 0n the 3rd December 2010. I have not had any problems with it until the note appeared on my laptop last week. Can someone...
Why has my genuine Windows 7 Home Premium turned 'Un-genuine'?
Hi Sevenforums, I've bought an Asus Laptop last year with a genuine copy of windows 7 Home Premium. But, as of today, it has turned 'un-genuine'. Why is it so? What can I do? Thanks!
ASUS Notebook - Genuine Windows but getting not genuine messages
Hi I have an ASUS notebook (U31F i5 with 4 GB mem) which until recently I used only occasionally. It has Legit Office 2010, but no CD/DVD drive. My desktop hard disk crashed in a big way so I am using the notebook as my main computer. It has just recently started throwing up messages that my...
