HELP ME please!!! OS not genuine Help Help me,Amigos
Page 1 of 3 123 LastLast
  1. Posts : 4
    window 7 starter 32bit
    Hi all,I need your help. There's lot problem in my head now.
    My netbook original OS is Win7 Starter 32-bit,my brother not know so much about OS.Then,he saw "window anytime upgrade",he try finding the product key in internet and i don't know where he found that,maybe at youtube. Suddenly when i open my netbook i saw win7 ultimate and "30-day to activation" lol!!!!
    Before, i try change back my product key to win7 starter at my computer properties. But can't undo update T_T. Now my window running in "not genuine". My dekstop all black and at down corner left dekstop wrote "win7 build 7600,this copy of window is not genuine'
    Now,I keep trying to change my product key,i try again go My computer and click properties try to change again but suddenly appear....
    C:\window\system32\slui.exe "window cannot access specified device,path,or file.You may not have appropriate permission". I try find another ways,like use cmd to change my key but can't too.
    Then,I try to reinstall window use win7 starter oem dvd given,i copy to external HDD coz i'm using netbook. During "setup is starting" ,
    "window cannot locate required file X:\Sources\install.wim" ERRor code=0x8007000D.That code maybe something about activation. Haihhhh,can someone help me please?
    I I just want my netbook like new brand again.I want my win7 starter back and i want format my HDD. Act i only 14years old n my english suck,hope you understand and..im not so good about computer Please reply ASAP!! Gracias!!
    Attached Thumbnails Attached Thumbnails HELP ME please!!! OS not genuine Help Help me,Amigos-untitled.gif
  2. Posts : 205
    Windows 8 Professional
    if you can, try to install using the cd. Grab an external cd drive and use that.
  3. Posts : 8,383
    He used an illegal upgrade key making your OS illegal too
    If your laptop has a recovery partition use it to restore the OS to default state
  4. Posts : 5,056
    Calm down, the feds are not after you. Lets do an experiment if you're upto it. Anytime upgrade would have created a restore point, so run system restore to revert to that point. I think you'd be easily able to make out that point in the SR options. If that runs successfully and you find Starter restored, you can enter the COA key on the back of your computer and activate.
    OTOH, if you're not upto it, just insert your recovery disks (hopefully you made them) and restore to factory default. If you didnt make them, there are other options, let us know.
  5. Posts : 1,210
    To explain further,
    Feds is Federal Bureau of Investigation aka FBI
    SR is System Restore
    COA is Certificate Of Authenticity
    OTOH is On The Other Hand
    Quoting Bill
    Calm down, the FBI are not after you. Lets do an experiment if you're upto it. Anytime upgrade would have created a restore point, so run system restore to revert to that point. I think you'd be easily able to make out that point in the System Restore options. If that runs successfully and you find Starter restored, you can enter the Certificate Of Authenticity key on the back of your computer and activate.
    On The Other Hand, if you're not upto it, just insert your recovery disks (hopefully you made them) and restore to factory default. If you didnt make them, there are other options, let us know.
    Sorry, couldn't resist
  6. Posts : 5,056
    Not to take away from the gravity of the OP's situation....but I've noticed the only acronyms that self-expand are win7 and AFAIK. IIRC doesnt expand, neither does OTOH, neither do some less charitable ones. Somebody needs to do an analysis...
  7. Posts : 4
    lunarpancake: yah..i'll try soon
    yowanvista :nope
    I have try use system restore but not have starter restored. And actually i don't get at all, just a little bit..by the way thanks so much spending time here reading my post. It will be nice if someone show me guide-by-guide to solve my problem .I know...it's my mistake not make backup file or system image or whatever...when first time i use this netbook. So..what should i do,just stay using this illegal window7 ultimate? Need i go to shop for repair or something? or format my com? i don't know la..give me some advice please.
    THANK YOU,May god bless you
  8. Posts : 8,383
    You could try a Repair Install
  9. Posts : 6,349
    I don't think he has a disk Yowanvista.
    Estoy buscando alguien que es fluido en español ayudarle.
    I am looking for someone who is fluent in Spanish to help you.
    Babel Fish translator.
  10. Posts : 8,383
    OP mentioned he has an OEM disk
