Windows 7: USB Problem. Need HELP BADLY.
02 Apr 2011   #11
gregrocker
Your stick may only support FAT32 as some do. With logical nothing can boot the stick. You might have had it bootsected (enabled to boot) somehow but Clean All wipes that out.
02 Apr 2011   #12
jademoore6
Windows 8.1 pro
Quote   Quote: Originally Posted by gregrocker View Post
OMG! the problem is till there..is there any other methods or options? when I copy those *.msi, *.exe, and *.rar to the stick, same problem, files are either corrupted or missing.
03 Apr 2011   #13
gregrocker
Then I'd replace the stick as it's clearly bad. I use an 8gb Kingston Data Traveler for the past 5 years without a hitch (carrying it in a baggie in my pocket). In that time the price has dropped by half on buy.com.
03 Apr 2011   #14
jademoore6
Windows 8.1 pro
well. thanks for your time helping me out, but as what I said on my first post, It got replaced with a new one using the warranty. So I'm thinking if there is some other problem that is causing this.
03 Apr 2011   #15
jademoore6
Windows 8.1 pro
any help?
03 Apr 2011   #16
gregrocker
In that case I'd use their Tech Support to find the problem, or replace it until it works.
Sorry but this is apparently very rare or someone would have jumped. I offered the wipe option because it's what I do when bootsecting corrupts my stick on occasion.
03 Apr 2011   #17
jademoore6
Windows 8.1 pro
sad to say, tech supports on USB sticks are not offered here on our country, they will just replace and replace and replace ^_^ anyway..I guess there's no solution for this. I even tried other USBs and find no problems copying my files.
03 Apr 2011   #18
gregrocker
I wonder if you can find an app that will format it NTFS instead of FAT32 to check the difference.
I'd use free Partition Wizard - installs in seconds.
While you're at it check the file system (once partitioned) and run a HD Surface scan.
If NTFS Logical is available, try it.
03 Apr 2011   #19
jademoore6
Windows 8.1 pro
well, without using the disk management tools, I manage to format my stick into NTFS format, but still, same problem, I guess I'll just get this be replace with a new one.. Time for sleep, thanks!
05 Apr 2011   #20
jademoore6
Windows 8.1 pro
Hi there, I just formatted the stick using the Partition Wizard you gave me into NTFS, the stick doesn't performs well, very slow. also run an HD surface scan and found 0 errors, It also passes the HD Tune Pro Test and found 0 errors on the drive. I think it's not on my USB, it's on something that I don't know.
need help badly
I am pulling my hair out. It started out cause My system HP Compaq 2010 win 7 64 bit, Stopped seeing or recognizing my Fuji Camera. Somebody said get a card reader, so I got this $6.00 one from big lots. Should be OK I thought. Still would not recognize card reader. So I don't know, maybe the...
General Discussion
Badly upgraded
Hey I've recently purchased an upgrade CD from xp to windows 7 after making sure I had all the criteria right. I followed the steps to the letter but when I tried exctracting the old files I got an error message saying "This version of update\update.exe in not compatible with the version of...
Installation & Setup
Need help really badly
Ok again i need help. Short verison of the story, some files are missing off my computer idk how many i only know of 2 and those are under My computer under S3A8955D004 click the User folder and there is usually 3 folders the one missing is default, now the other folder you Click on the one that...
General Discussion
New Help Badly... BSOD
I have followed the BSOD - Posting Instructions and need some help finding out why my system keeps crashing. Please help I am running windows 7 home premium
BSOD Help and Support
Need your help so badly.
I previously have a dsl connection provided by pldt before and thats the time that i used windows 7 and activated it online. after few months ive changed my internet provider to smartbro wireless internet but when i reformatted my pc and reinstalled my windows 7 again and tried to activate it...
General Discussion
