Windows 7: USB Problem. Need HELP BADLY.
05 Apr 2011   #21
gregrocker
Microsoft MVP
Add your apps one by one until you find the one corrupting stick.
05 Apr 2011   #22
jademoore6
Windows 8.1 pro
Quote   Quote: Originally Posted by gregrocker View Post
actually, I tried putting some pictures/videos on the stick, the pictures were broken and some pixels are misplaced or gone, videos are corrupted and unable to play. when I reconnect the stick, Pictures are gone videos are corrupted.
I'm out of options, I'm thinking now, does all USB sticks they are selling in that shop is this kind?
05 Apr 2011   #23
jademoore6
Windows 8.1 pro
Quote   Quote: Originally Posted by jademoore6 View Post
the picture that I'm saying is like this, I'm thinking that the stick is damaged, but HD Surface Scan and HD tune Pro don't detect any errors. http://www.fileden.com/files/2007/9/...re%20pixel.png
05 Apr 2011   #24
gregrocker
Microsoft MVP
Did you check the file system using Partition Wizard or Disk Check?
05 Apr 2011   #25
jademoore6
Windows 8.1 pro
yes, I do that several times and passed the test, I'm now running several test using the HD Tune Pro. and it seems that It passes all the test I throw into it.
05 Apr 2011   #26
gregrocker
Microsoft MVP
Try another brand of USB stick. I recommend Kingston as their RAM is second to none and tech support is fantastic.
05 Apr 2011   #27
jademoore6
Windows 8.1 pro
I forgot to mention, my first USB stick I purchased from them was KINGSTON Data Traveler, when I replaced it, I choose Transcend that let me to add additional fee because transcend is more expensive than KINGSTON. both are 1GB.
05 Apr 2011   #28
gregrocker
Microsoft MVP
Then I doubt it's the stick. It is something about the formatting or the way the files are loaded.
05 Apr 2011   #29
jademoore6
Windows 8.1 pro
I'm now thinking I better bought those cheap sticks selling here on a less 25% of branded price, one of my unbranded sticks serves me for about a year now from the 1st purchased, it just got busted when I accidentally unplugged it from the system and causes the failure. (PC won't detect the stick.)
Well I guess this tread can now be closed, unsolved ^_^
05 Apr 2011   #30
gregrocker
Microsoft MVP
I wish you would have let Kingston tech support help you figure out the issues - they're very engaged with what their memory is doing or not doing.
Try the manufacturer tech support for the brand you have now. It may even be a known issue but unseen here by someone who knows the issue.
You should be able to clean all and reformat the stick that was unsafely removed: Clean and Clean All with Diskpart Command - Windows 7 Forums
need help badly
I am pulling my hair out. It started out cause My system HP Compaq 2010 win 7 64 bit, Stopped seeing or recognizing my Fuji Camera. Somebody said get a card reader, so I got this $6.00 one from big lots. Should be OK I thought. Still would not recognize card reader. So I don't know, maybe the...
General Discussion
Badly upgraded
Hey I've recently purchased an upgrade CD from xp to windows 7 after making sure I had all the criteria right. I followed the steps to the letter but when I tried exctracting the old files I got an error message saying "This version of update\update.exe in not compatible with the version of...
Installation & Setup
Need help really badly
Ok again i need help. Short verison of the story, some files are missing off my computer idk how many i only know of 2 and those are under My computer under S3A8955D004 click the User folder and there is usually 3 folders the one missing is default, now the other folder you Click on the one that...
General Discussion
New Help Badly... BSOD
I have followed the BSOD - Posting Instructions and need some help finding out why my system keeps crashing. Please help I am running windows 7 home premium
BSOD Help and Support
Need your help so badly.
I previously have a dsl connection provided by pldt before and thats the time that i used windows 7 and activated it online. after few months ive changed my internet provider to smartbro wireless internet but when i reformatted my pc and reinstalled my windows 7 again and tried to activate it...
General Discussion
