I need some help for annoing problem
  1. Posts : 3
    What should I do to make this thing to disappear? It's happening on almost every dropdown menu that I use (include right-click menu > regresh).
  2. Posts : 352
    Windows 7 Home Premium 64-bit
    I assume you mean the "category" bar and not the background image.... LOL.
    What programs are running in the background (should be listed on the taskbar) - once you find out which one is generating the menu, you should be able to go into its properties and switch it off.
  3. Posts : 3
    Thank you!
  4. Posts : 352
    Did you figure out what the problem was ? - if its fixed, mark the post as "solved" (green tick at the top) so others know its finished. Thanks.
  5. Posts : 3
    I've just closed "dreamweaver.exe" process (cuz when I've installed that software, my probles has started to appear), and after that, I've waited for about 1-2 h.
  6. Posts : 16
    Is it the little tools that windows 7 loves to use?
    Just remove it and it'll be fine.
    You can uninstall it from there.
    If it doesn't work then pm anytime!
    Thanks!
