Internal SATA, clean install and 32 bit, I've had the issues with iso's direct from microsoft as well
i have noticed since running build 7100 that when i go to access my other two hard drives that it will sit there for about 20 seconds before allowing further access. i thought it was just a problem with the drives. i reinstalled vista and i do not get the problem. i go back into 7 and the problem is back. i do not think 7 is fully supporting the chipset software yet. the reason i say this is the fact that under the beta 7 had a problem with the usb controllers and would drop all usb devises when i would unplug just one. hopefully once the full version comes out mikey-soft will have address this problem.
