Serious, Serious Problems. Help Appreciated!
Page 2 of 2 FirstFirst 12
  1. Posts : 1,161
    Windows 8.1 PRO
    kylepsp said:
    I think it was actually a torrent supplied by someone on this site.
    This post was always there?
    Damn. I missed that
  2. Posts : 12
    Windows 7 RTM
       #12
    Internal SATA, clean install and 32 bit, I've had the issues with iso's direct from microsoft as well
  3. Posts : 28,845
    Win 8 Release candidate 8400
    K
    On a new clean install, do you get those service errors? Have you upgraded the bios? have you upgraded the 945gm driver?
  4. Posts : 114
    Windows 7 Eternity Build 7600 RTM Activated x86
       #14
    i have noticed since running build 7100 that when i go to access my other two hard drives that it will sit there for about 20 seconds before allowing further access. i thought it was just a problem with the drives. i reinstalled vista and i do not get the problem. i go back into 7 and the problem is back. i do not think 7 is fully supporting the chipset software yet. the reason i say this is the fact that under the beta 7 had a problem with the usb controllers and would drop all usb devises when i would unplug just one. hopefully once the full version comes out mikey-soft will have address this problem.
  5. Posts : 12
    Windows 7 RTM
       #15
    zigzag3143 said:
    K
    Yes I do, yea driver programs say I'm up to date. However am not sure about how to upgrade my bios, my laptop was store built so I dont really have many settings to fiddle with in the bios, how could I upgrade it?
