Bold font problem in programs (Not the average problem)
  1. Posts : 6
    Windows 7 Pro x64
    This isn't your average bold font / italics problem. This problem doesn't occur in windows folders or anything, it happens in only a few programs. It happens in Ventrilo (https://i.imgur.com/u6e00.jpg) and it happens in Sony Vegas which cuts off my window (https://i.imgur.com/oDFdc.jpg) .
    You may notice that if you've ever used those programs, the fonts aren't bold like that. My DPI is at 100%, I've tried re-installing my fonts, setting the default settings, and it doesn't change with themes. I want to avoid re-installing windows, and if that's the only option, I guess I'm just gonna have to live with it. Any help would be appreciated! Thanks!
  2. Posts : 1
    Hi I also have the same problem if anyone could help with this it would be great cause in the main set of options I can only see "BOLDED" areas in drop down options every where GUI display panels etc ...
  3. Posts : 6
    Windows 7 Pro x64
    Bumping this because i still have this problem
  4. Posts : 5,440
    Looks like the problem is with your actual programs not with Windows. Where did you get your copies of the programs that are causing problems especially Sony Vegas?
