Problem with system reserved partition.
Page 1 of 3 123 LastLast
  1. Posts : 15
    Windows 7 Professional x64
    Hello sevenforums,
    I accidentaly deleted the system reserved partition(100mb) and now I'm getting the error "Windows cannot be installed to this disk".
    It's a clean HDD.
    I'm waiting for an answer. Thank you.
  2. Posts : 13,576
    What are you trying to do ?
    It can`t be a clean hard drive if it had a sys res partition on it.
  3. Posts : 15
    I mean , i erased all what I had on the HDD including the sys res partition and now i have : Unallocated Space 160 GB , and if I try to make a partition it says "Windows cannot be installed to this disk"
  4. Posts : 78
    Ultimate 32bit
    Try formatting it through cmd or installer and install windows .
  5. Posts : 13,576
    Don`t know why. Just install to the unallocated space.
    You should be able to just click next.
  6. Posts : 15
    How can I do that?
    And I can't install windows to that unallocated space, because i get this error: 'Windows cannot be installed to this disk. This computer's hardware may not support booting to this disk. Ensure the disk's controller is enabled in the computer's BIOS menu.'
  7. Posts : 13,576
    Are you sure you have deleted ALL partitions ?
  8. Posts : 15
    Yes, I'm 100% sure, I'm talking now from a laptop, i got the PC in front of me.I have just that Unallocated Space, nothing else.
  9. Posts : 13,576
    Next question is.... Where did you get the windows 7 installer ? Has it been used successfully on other machines ?
  10. Posts : 15
    I wanted to reinstall my windows(It's my routine once at 5 months), with the same CD. I tried with 3 different windows 7 CD's , same problem..
