Need a bit of help/advice.
  1. Posts : 79
    Windows 7 Ultimate x86 7600.16385
    I've got a major problem.. About two hours ago, I accidentally deleted my .ISO image for Windows 7... Obviously it's not available for download from Microsoft anymore, and a download from somewhere else would take too long.. any way I can undelete it or something? I need the ISO image sometime in the next 3 hours. Any help would be appreciated.. Thanks
    Oh, also, if it helps any, my current OS is Windows XP Media Center Edition. I believe that is the equivalent of Windows XP Professional.
    ~TA
  2. Posts : 8,476
    Windows® 8 Pro (64-bit)
  3. Posts : 9,606
    Did you look in your recycle bin (Trash Folder) to see if it might still be there ?
  4. Posts : 79
    @Dinesh - Thanks, I'll try it.
    @DocBrown - 2 GB is too large for the recycle bin, when I deleted it, it was deleted permanantly.
  5. Posts : 5,747
    7600.20510 x86
    R-Studio might be able to recover it. Whatever you use, do a hash check on the file compared to known value, when you're done.
  6. Posts : 79
    Finished trying both R-Studio and Recuva. Neither was able to recover it. Does this mean I'm screwed? D:
  7. Posts : 8,608
    Windows 7 Ultimate 32bit SP1
    How do you think you (accidently) deleted your .ISO file?
  8. Posts : 79
    I didn't "delete" it per se, I was using a program called MagicDisc, and was getting ready to mount the .ISO onto a virtual drive, and I clicked something.. and a prompt came up, showing the name of my .ISO, and asking if I would like to replace it. I wasn't really paying attention, so I clicked yes. Low and behold, my .ISO image was down from 2GB to 4KB. I felt saying "I accidentally deleted it" was easier than this explanation. :/
  9. Posts : 8,476
    Sorry mate. You will need to reinstall it.
  10. Posts : 79
    *sigh* Thought so. Thanks for the help guys.
