Encrypted Volume Check: Volume Info on \\?\Volume{X}Can't read
Page 1 of 3 123 LastLast
  1. Posts : 1,024
    Windows 7 Ultimate
    Encrypted Volume Check: Volume Info on \\?\Volume{X}Can Not Read
    Found this in my Event Viewer on each start/restart. I don't have any Volumes that I have encrypted. Is this malware? I've run everything prior to noticing including Windows Offline Defender.
    Not sure if this is even the correct area to post this!
    Glenn
  2. Posts : 3,056
    Windows 10
    I'm going to take a guess, please upload a screenshot of the disk manager (Windows Key+R to open the Run dialog, type diskmgmt.msc, and press Enter).
    Posting the actual entry from the Event Viewer can help.
  3. Posts : 1,024
    Windows 7 Ultimate
    Hello and thanks for responding. Here is a view from the event viewer, I'll do it with diskmgmt.msc if it is still necessary!
    Encrypted Volume Check: Volume Info on \?\Volume{X}Can't read-capture.png
    Glenn
  4. Posts : 1,024
    Windows 7 Ultimate
    Here is the diskmgmt shot!
    Thanks for any assistance!
    Glenn
  5. Posts : 3,056
    Windows 10
    The more info the better the thing I don't quite understand is how is this an issue in your eyes?
    Have you experienced any problems?
    I don't have Windows 7 Ultimate so I can't try and reproduce this condition.
    I would go into the registry and search for the value inside the {} to see who's it's parent.
    A word of caution! DON'T change anything.
  6. Posts : 1,024
    Windows 7 Ultimate
    Hello YoYo155,
    I don't have the experience of confidence to try that without help..... But looking at the disk management page on Disk 0 the first 100 MB partition is supposed to be the System Resereved IIRC. It is now unnamed and doesn't look right!
    Any ideas?? Thanks again
    Glenn
  7. Posts : 17,322
    Win 10 Pro x64
    Mine is unnamed too, it is still system reserved though.
  8. Posts : 3,056
    Windows 10
    No I don't believe that to be the problem, or any problem for that matter.
    If I may ask, what made you go and look in the event viewer in the first place, did some issues arise?
    with that said, you can look in the registry by Windows Key + R and typing regedit then pressing Enter (accept the UAC [User Access Control]).
    In the registry the first thing you do is File>Export (make sure that the export range is set to All [a bullet point at the bottom left]) and save a backup.
    Then hit the F3 key and enter the string (the series of characters between the {} and search.
    Let us know if something comes up.
    But really I have to stress is there a problem?
  9. Posts : 1,024
    Windows 7 Ultimate
    Thanks Derek,
    I thought I remember it being different, the last time I looked at it. Thanks for confirming!
    Glenn
  10. Posts : 19,383
    Do you have TrueCrypt installed? Any encrypted containers?
